Highbredcloud
bluevenom867 said:What the hell, TFS TW is only 5cc big intake runner.Plus there as cast and most come out with a little smaller than 170cc (like 169/168cc).That really isnt much considering the AFR 185cc are 15cc bigger and have the same size valve, they flow more because there ported, but yet the TFS TW was only 10hp behind and with less compression.Highbredcloud, if you wanna talk BS about how your AFR heads are so great, then why didn't MM&FF compare the TFS TW to the AFR 165cc?They had to put it in the same group as the AFR 185cc, and I know for a fact that the AFR heads flow more (not the 165cc), but the TFS TW hav the special bowl desine.You forget to mention bowl work as one of the thing I said to "clean up" and that also mean removing casting flaws in the run and then going over it with 80 grid cartrage roll to smooth out the rough spots.The exhaust would get a gone over with a polishing head until there like glass smooth.And the AFR 165cc/AFR 185cc are only avaliable in 58cc and 64cc.Um, hate to say it but, the TFS TW flows 251cfm at .550 on the intake and was only a few cfm behind on the exhaust.I want to know what TFS test flow with.AFR flow benched there head on a 4.060 bore with a 1 3/4 header.How many of you out there run your motor .060 over?Not that many, so you lose some flow right there.AFR also shows that the AFR 165cc emission legal heads flow less, by about 5cfm on both sides, than non emission AFR 165cc, so there would be a differance in power.So, I still say
AFR 165cc<TFS TW
Calm down...relax...start breathing...I'm not the one talking BS...the facts are right there if you are willing to take your time to actually research the topic...IT has been proven time and time again that AFR's make more power under the curve than the TW's...NOTICE how I said under the curve and not just peak HP...I do agree that the combination has a lot to do with this matter than the head alone...I have no idea why MM&FF comapre the TW's to the AFR's 185's...YOU can call and inquire about that...It's funny how I'm talking out of the box heads...and then you go ahead and keep saying about a clean up job to the TW's...well guess what buddy...to blend the bowls and polish the chambers and even port/smooth the exhaust for to a perfect 1415 Fel-Pro gasket...that right there will abe about $400.00+...in labor by a reputable head porter and not some nobody with a dremel...Like I said before...just polishing will do nothing...The fact that the TW's have a bigger valve on the intake tells me that AFR must have done something right to achieve the near same flow with a smaller valve and a smaller intake cc...Common sense here...Stick to the subject and don't get all confused...There are different heads out there that will flow better than both AFR's and TW's once slightly cleaned up...i.e...the GT-40X's...I'm talking right out of the box...AFR's will give you better results...is it worth the money? Probably put this in the same perspective as porting or slightly cleaning up the TW's heads for $400.00 more...
YOU are full of wasted knowledge about this topic especially AFR's...AFR 165's come in 54cc, 58cc, 60cc, 61cc...not sure about the 64cc...go to the website and check it out for yourself...www.airflowresearch.com While you are there you can also see the flow number with the emmision legal AFR 165's and the non-emission legal ones...prove me right! I have nothing against TW's, they are a good head but I like the fact of a smaller head making as much HP as a bigger one...I will say this again...TW's have more meat on them if you want to port them...and do flow once ported...Still a very good head for the money...I would really like to know where you get your information from...
-Greg
IMO an afr 165, TW and an edelbrock performer head will all make similar numbers with the right cam/intake. Some people are just brand loyal and thats how they go about recommending parts. Not cool. My advice is pick one out of the 3 I listed and have the combo designed around that and I bet it'll run good.
and relize that you both have some good heads and relize that the other side isn't always wrong.
maybe an a-trim or something small.
