I was comparing the engineering development on these heads (AFR165)with my p-heads, and simply there´s no comparison. The ducts flow smoothly and are HUGE! Besides, the weight is ridiculously low. I still didn´t measure the valve coils specifications but they´re double with damper. Some small work can be done on the exhaust ducts, near the valves guide, to eliminate a small degree and in the intake after the intake hole, imediately after the curve is upwards. I´m a believer on the p-heads, but these AFR are outstanding!
