AFR'S 165 Q's
green9150
I havent been on this page in a long time, but i ran into a problem and new this was the best place to ask. Here is the set up
COMPLETLY STOCK BOTTOM END
AFR'S 165 61CC CHAMBER
TRICKFLOW STREETHEAT
E-303 Cam
DSS 1.6 RR
FELPRO- TRIPLE LAYER 1133
My question is i have already bought the 61cc heads and was told that my compresstion would be 9:1. when i talked to people about my combo some advised to go with 58cc heads that would get me 10:1. thats the big question do i keep the 61cc or go with 58cc and exchange for no cost. Its in a aode 3k stall and 4.10 gear. the perpose of the combo was to run 150 shot and i will before the season is over. Would like to run pump at alltimes but dont think that 10:1 would be a problem. Howmuch HP would i be lossing at the wheels with the lower compresstion. ALSO i have the engine out and would would also like to know if you guys think the e-303 cam is sufficient or should i get a spray cam for the heads. looking to get into the high 11's. I KNOW THIS IS THE BEST SITE TO ASK
THANKS GUYS FOR ALL THE HELP AND PLEASE ADVISE ON IF YOU THINK I SHOULD CHANGE THE SET UP OR ADD NEW ADDITIONS. THANKS AGAIN
First off, 3 cc is NOT going to get you a full point of compression. Second, if you already have the 61cc version and want more compression spend 80 bucks and have them milled. To get 10:1 you will probably have to mill them to around 54cc or so or maybe a little less.
