aftermarket camshaft
  • Thread starter Thread starter trlps_
  • Start date Start date Feb 7, 2021
trlps_
26
Houston
Feb 7, 2021
  • Feb 7, 2021
So I'm looking at upgrading my cams, just out of curiosity what would be the best cam to run on a stock tune and without changing springs? I'll eventually change out the springs but just not in the budget currently. Any preferences or anything that anyone could suggest? Thanks in advance
7991LXnSHO
wanna catch the space herp
7,387
2,745
194
Kearney, NE
Feb 7, 2021
  • Feb 7, 2021
Stock will be best. But you can get by with other cams as long as the lift does not cause coil bind, and the springs can handle the more aggressive profile without floating. Call the cam manufacturer for recommendations.
Reactions: trlps_
D
Deleted member 38176
Feb 7, 2021
  • Feb 7, 2021
I'd wait until you can upgrade the springs to get cams. Getting mild cams that dont require spring pretty much negate needing to upgrade the springs at all.
Reactions: 1low03gt and trlps_
Adizzle843
83
30
28
South Carolina
Feb 8, 2021
  • Feb 8, 2021
I agree with nightfire. To get cams mild enough to not upgrade the springs isn’t worth it, and if you are going to replace the springs later you will have to be in the heads again, at which point you will prob want a more aggressive cam. Best to wait and do it all at once.
Reactions: 1low03gt, trlps_ and Deleted member 38176
trlps_
26
Houston
Feb 11, 2021
  • Feb 11, 2021
After giving it some thought I changed my mind and agree lol so now here's another question I do have, im looking at the xe270ah from comp, I know this will need a tune but is there any other cams that won't require a tune? I've seen some say yes and some say no but doesn't hurt ask yet again lol
Adizzle843
83
30
28
South Carolina
Feb 11, 2021
  • Feb 11, 2021
My best advice, which could be wrong (and probably will be corrected if I am) is to figure out what kind of build you want to do. Buy your cams according. Do you need NA cams vs Supercharger cams vs Turbo cams. They might add some hp, but they also change where you are making power in the power band, so you might want to think about changing gears.
Back to the original question, I don’t think they will require a tune to run, but the tune is to optimize your car for the cams you installed.
Reactions: Deleted member 38176
D
Feb 12, 2021
  • Feb 12, 2021
Get an idea of what you want to do with the car. Turbo build? Supercharger build? N/A build? BELIEVE ME, leave the cams to the very end! Then have Todd Warren custom-spec you cam to give you the most out of your setup
7991LXnSHO
7,387
2,745
194
Kearney, NE
Feb 12, 2021
  • Feb 12, 2021
With as many off the shelf designs there are, a custom picked cam for a 5.0 will be a great fit. A custom grind is not likely needed for almost all of our builds. If you want to wait and have the cash, it may be worth the bragging rights. But it’s not like you are building a six cylinder or a rarely modified engine.
Either way, you need all the vehicle info ready and call the cam support line.
The rest of the info from Nightfire is financially sound.
Reactions: trlps_ and 1low03gt
Engine Donor '00 Mountaineer meet '91 Fox
  • 91firecracker
  • May 11, 2026
  • 2 3
Fox 5.0 Mustang Tech May 28, 2026
91firecracker
9
T
First Car, what should I do for power??
  • tunedV6
  • Apr 13, 2026
1996 - 2004 SN95 Mustang -General/Talk- May 4, 2026
580HP*428Cj
Engine Suggestions on an engine rebuild. Stock cam/GT40Ps or aftermarket on both for a fun weekend driver?
  • MadSquirrelTech
  • Apr 28, 2026
Fox 5.0 Mustang Tech May 7, 2026
MadSquirrelTech
Fox Good shop in Washington state or Oregon
  • keel
  • May 14, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 20, 2026
keel
Preparation for Holley Terminator X install – Foxbody 306 (electrical fan, alternator, MSD Ignition, etc)
  • So_Flo
  • Mar 1, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 4, 2026
General karthief
