aftermarket clutch?
95cobra50
167
Well I am going to be needing a new clutch. I plan on staying with in the 350-400hp area for about 6 months then starting h/c/i to really set my s/c off. So what kind of clutch should I be looking at? Spec 3 is all i have hear from a few buddies but i though some of you might know something else that might be better. THanks
I have an old design spec stage 3F and it stuck on me the other day. I had to pull the tranny out and un-stick the disc from the flywheel. When I talked to the guys at spec they said they don't make them like mine is anymore. Seems like it was a pretty common problem.
I don't see why you couldn't use your stock flywheel with thier clutch.
SQUEEZE&STROKE said:
Centerforce dual friction-never had any problems always works well-car wnt 11.70's-probably around 430-470hp (All stock Suspension, bfg drag radials)
I destroyed 3 C/F D/F's in a matter of months. :notnice:
I may be a little harder on my clutches than most. I gess it depends on what he wants to do with his car. :nice:
I'm on my second CF DF in my second car, never had a hint of a problem with either! And by no means baby my car (Accept for the daily car wash). :cheers:
You really must drive the living @#$% out of that car!!! Well thats what there made for :nice:
