I have a set of aftermarket fuel rails im installing right now. Because i still have the stock distributor i had to grind a little on the fuel rails and trim the distributor a little to get the one side to fit at all.. They rub are touching now but i don't think it will cause any problems?
What brand of fuel rails are people running and do you have the same problem im running into? I have a set of 1/2 ID Proffessional Products. If so what did you do? Different distrubutor?
Currently the rails are spaced out a little. It looks like there is a good seal on the injectors but i won't know for sure till i start it up. It got dark and i started the prodject outside so i didn't even get a chance to put some pressure to the system to check the lines.
Also where did you mount the bypass regulator?
