aftermarket mirror question
wolf39us
37
alright so I have a convertible...so it is pretty necessary that I have map lights...but I have a question...if I upgrade my factory mirror to an aftermarket mirror with map lights, auto dimming, compass and temp...do you think that the map lights would normally turn on when I open the doors...
my mirror does not have a switch built onto it (I'm pretty sure I can only turn them on using the headlight switch and twisting it to the left)
all the aftermarket mirrors I have seen come with switches for each individual map light....so I was wondering if that would interfere with the map lights turning on when I open the door?
here is the mirror I was looking into
http://cgi.ebay.com/ebaymotors/ws/e...viewitem=&item=230238490479&_trksid=p3907.m29
My thought is the wiring probably has at least three wires; ground, power, and accessory... That being the case, find where the wire is for your traditional door lights to come on and tap into that for your accessory wire. Then again, I have never wired a mirror so I could be way off but it could be a start. It may be activated on a solenoid which would also be easy to wire. Just go to your local autozone/schucks and purchase a relay switch and hook it up tapping into the same wires.
Hope that helps! :)
