Yellow302 Member Mar 2, 2003 789 2 19 NJ Sep 7, 2007 #1 Sep 7, 2007 #1 With my novi 2000 the belt chewed a hole in the overflow tank and it now sending coolant all over my engine. I need replacement options and the tank can be mounted anywhere. Thanks for any responses.
Blackened302 Active Member Jul 21, 2005 1,439 0 36 South TX Sep 7, 2007 #2 Sep 7, 2007 #2 i've seen aftermarket overflow tanks at Advance--maybe one of those might work?
94-302-vert Active Member Aug 16, 2004 1,947 2 36 NE CT Sep 7, 2007 #3 Sep 7, 2007 #3 How about a universal catch can from summit or jegs so you can relocate it?
The Green GT No 13 year olds are safe around me. 10 Year Member Jan 8, 2006 1,269 19 99 Louisiana Sep 7, 2007 #4 Sep 7, 2007 #4 Ive seen the universal ones put up behind the bumper. Or you could drop $150 on a shiny chrome one that will go in the stock location.
Yellow302 Member Mar 2, 2003 789 2 19 NJ Sep 7, 2007 #5 Sep 7, 2007 #5 i want to get it out of the stock location. I could put one by the batery, since i have the relocation kit sitting in my basement.
94-302-vert Active Member Aug 16, 2004 1,947 2 36 NE CT Sep 7, 2007 #6 Sep 7, 2007 #6 http://store.summitracing.com/egnsearch.asp?N=700+4294924500+115+4294921541&NeXID=5
HISSIN50 "How long does it take to get help in here? 15 Year Member Nov 29, 1999 31,179 33 129 Sep 7, 2007 #7 Sep 7, 2007 #7 If needing something temporary and pretty cheap, you can do something like this: (Note the pic was taken while I was making it, so it's not all nice and pretty). Or you could use your windshield washer reservoir for the coolant. That's been done before. Good luck.
WHITE94COBRA New Member Nov 14, 2003 816 0 0 HUNTINGTON BEACH Sep 7, 2007 #8 Sep 7, 2007 #8 Canton stock location, but all aluminum construction.
95cobraguy Member Dec 23, 2005 637 11 19 Concord, NC by way of LI, NY Sep 7, 2007 #9 Sep 7, 2007 #9 i used this one and used a big hose clamp to secure it to the radiator support in front of the radiator, right next to the airbag crash sensor. http://store.summitracing.com/partd...4294924500+4294921541+400105+115&autoview=sku
Pokageek Active Member Jun 10, 2005 2,767 0 46 MA, USA Sep 7, 2007 #10 Sep 7, 2007 #10 I went with the one made by summit for $13. and I put it in the fenderwell and ditched the coolant over flow bottle sensor.
