Aftermarket Stereo Install to Subwoofer Syst
stangstooge
Has anyone had experience installing an aftermarket stereo in place of the ole "Skipper 500"? How do you re-connect the Sub woofer amp? The new unit has pigtail connections with rca jacks.
Installed Alpine 9885 on Friday
Didn't do it myself. I had a very reputable Orlando car audio company install. Took them less than an hour.
Unit has great MP3, home burned disk play ability - unlike the Shaker 1000. More sub controls... rather than low, low and louder.
Red and Blue color scheme on the new head unit compliment the blue/red instrument cluster nicely.
Roughly $420.00 out the door, including iPod connect in glovebox.
Installers said it is easy, simple harness - I hate the idea of breaking a dash panel or it not going back the way it came, let a pro do it.
Did a break job earlier in the week, give me a break :)
you need a line output converter. its a little block that has rca inputs on one end and regular speaker wires on the other. i just replaced my alpine head unit for a double din jvc, which btw is the best!!!!:nice:
Do you have pics, i have the alpine cda 9983 (im think im at work so cant check), but that extra pocket is just and eye sore, i want something to fill it and a double din would be great to have in there ! (sorry to jack the thread guys)
THANKS FOR THE INFO. I GOT THE RIGHT WIRE HARNESS FROM CRUTCHFIELD AND INSTALLED BUT THE SUBS DON'T WORK, AS FARE AS I CAN TELL FROM THE FORD WIRING SCHEMATIC THE SUB AMPS ARE POWERED SEPERATELY FROM THE RADIO. ANY SUGGESTIONS?
my subs didnt work either after changing out my head unit. what i found was the subwoofer settings in the aftermarket radio were preset to zero. hope that helps:shrug: im assuming you wired in the voltage regulator correctly
Call Crutchfield Tech Support, they will surely help you. My buddy used to be one there.
