ah...gimmee a break...
95rgvstang
i am in need of some help here. i have a 95 gt with a 347, custom cam, tfs heads, gt-40 intake, 24 lbs inj., msd 6al, msd coil, autolite plugs, accel wires, new distibuter(ford motorsport), timing set 16 advance, fuel pressure set at 42-45. here is the problem. damn thing wont run for ****....at idle car sounds great, put in on the street, pings, stutters, tries to shut off, erratic idle, 450-1700 rpms, i am tired of spending money on this thing....i am a competent mechanic, this car just not want to run...any advice will be greatly appreciated. ty.
must b a stang said:
What MAF do u have.
sounds a bit like my problem. my car idels, and even drives real good at part throttle, but when you floor it, it does what you descibe. i had it at kauffmans. they put it on a computer system (looked similar to a tweecer) and found out its the MAF... not working at all. :(
do any of your friends local have a tweecer system that they can hook up your MAF to and see if its working correctly?
