Ahh? WHats going on??
nos707
108
UK
Hi Guys,
Im new on here, although I have been visiting the forum for a little while.
I am in the UK, and have a 93' 5.0 GT.
The other day, I went to start it, when it just turned over. This was a suprise because it normally starts first time.
It wont start unless you five it full throttle when turning over.
This morning I started it (finaly) and it was on 7cyl! I let it idle for a while, but it dodn't clear. I took it down the road and when I got back the temp was nearly 240!
Whats going on?
I cant see any water in the oil!
If you have electric fans are you sure there turning on? If thats not it, it may be a stuck t-stat. check and make sure your antifreez is full and if so the check the other thing I listined above.
As far as not starting I think we would need a little more info. When was the last time a full tune up was done? fuel filter? probley should check and see if there are any codes in memory also. Good luck
Thanks for replying!
The fan works fine. Its never got that hot before, and def not that quick!
I have just checked the oil filler cap again, and there is some water in the oil. It was clean yesterday, cause I checked it before I went out!
The motor ran great yesterday, kept cool felt good. Then first thing this morning, this happends!
The motor was rebuilt this time last year with Holley Systemax ally heads, intake and headers.
Eagle Rods, and crank,TRW pistons, and lunatti roller cam.
I didn't build it, so I am guessing that the fuel filter, plugs ect are all new! The motor has prob only done 5k since rebuild!
It doesn't say so in your post (so correct me if I'm wrong) but I get the impression that this car has been sitting a while.
If so, start by changing your fluids and putting some gas dryer in the tank. Allow that stuff to work it's way through the fuel system before driving. Once complete, run the tank down till the low light comes on before putting new gas in and see what effect that has.
Get a code reader and pull codes. See if something else screwy is ging on like a stuck EGR valve or something.
I use the car daily!
Its run perfect up untill now!
What is the cost of a code reader & is there a choice? If so, which are the best?
I am thinking that it is a head gasket! This is my first Mustang, and my first ally head removal!
What head gaskets should I go for?
Im thinkng a felpro full engine set? As I will need manifold gaskets etc.
What do you guys think?
It sounds like you have blown head gaskets. Did you pull the dip stick and see if that is milky? if the oil on the dip stick is milky then thats what it sounds like. As for a code reader you can get just a basic one for prob around $30 or so on e-bay. I think that what i paid for mine and it came with a small book to tell you what the codes ment. Just make sure it covers your year. You wouldnt need a full engine set unless you are pulling the motor. You should be able to get just an upper engine kit but I would price it to see which way is cheaper for sure. sometimes it is cheaper to just get the whole set. Im not sure if you nead a spacific gasket typ for aluminum heads or not. Good luck
he said thers no water in the oil.. Did you check ur radiator?? Mine was completely down over night, because my water pump went, and it leaked out the weep hole in teh water pump and i didn't even realize it, than over night it was getting crazy hot in like 15 min... better correct the problem before you hurt something, my overheating led one of my bearings to go bad, and thus needed a new shortblock
Paul Perreca
Dump the codes and see what the computer says is wrong…
Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great.
See http://www.troublecodes.net/Ford/
OR
See http://www.mustangworks.com/articles/electronics/eec-iv_codes.html
IF your car is an 86-88 stang, you'll have to use the test lamp or voltmeter method. There is no functional check engine light on the 86-88's except possibly the Cali Mass Air cars.
For those who are intimidated by all the wires & connections, see http://www.actron.com/product_detail.php?pid=16153 for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Walmart.
Or for a nicer scanner see http://www.midwayautosupply.com/detailedproductdescription.asp?3829 – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $35.
