ahhh SOB
  • Thread starter Thread starter ryan218
  • Start date Start date May 14, 2007
  • 3
  • 4
  • 5
First Prev 2 of 5 Next Last
ryan218
In just 10 years, I'll be old enough to drive!!!!
Dec 28, 2005
columbus ohio
May 14, 2007
#21
  • May 14, 2007
  • #21
grey5.0beast said:
dang I would have sent you one of those too lol. Why not upgrade while you were in there? They aren't that much
get it painted before up grades is more important this time around...take all of 10 mins to drop the tank and get the fuel pump out...ill put a bigger one in there when i the car needs it...
idk i just want this to run better.......although...where i have the timing set now makes it sound like it has a nasty cam in it...lol i think i related it to much or did i advance it
grey5.0beast
Cookies should never be DUNKED!!!
Aug 3, 2004
atl ga
May 14, 2007
#22
  • May 14, 2007
  • #22
get a timing light!!!!!!!!!!!!!!
ryan218
Dec 28, 2005
columbus ohio
May 14, 2007
#23
  • May 14, 2007
  • #23
im cheap...im not paying 100 bucks for one!!!
Darkwriter77
Resident Ranting Negative Nancy
5 Year Member
Jul 1, 2005
315
283
134
Apache Junction, AZ
May 14, 2007
#24
  • May 14, 2007
  • #24
Ideas off the top of my head:
- Defective fuel pump (how many PSI are you getting at the rails @ idle?)
- Vacuum leak (check alllllllll of your vacuum lines, listen for hissing, double-check all those stupid hard plastic lines that tend to get brittle and crack)
- Check your TPS voltage
- Bad fuel pressure regulator
- Check for exhaust leaks ahead of the o2 sensors (mine started running really weird when my passenger-side downpipe worked itself loose at the header flange)
- Bad injector(s)
- Faulty pickup coil
- Valve(s) not fully closing? (Broken/weak valve spring(s)?)
mustangjoe87
364
Harrison Twp., Michigan
May 14, 2007
#25
  • May 14, 2007
  • #25
they aren't that much chief
ryan218
Dec 28, 2005
columbus ohio
May 14, 2007
#26
  • May 14, 2007
  • #26
one i was looking at was!
RsStanG1987
I shaved all my pubes playing this game.
569
9
79
Dupont PA
May 14, 2007
#27
  • May 14, 2007
  • #27
They are like 10 bucks at wal mart there buddy..
ryan218
Dec 28, 2005
columbus ohio
May 14, 2007
#28
  • May 14, 2007
  • #28
- Bad injector(s)
no idea how many PSI im getting...dont have a gague....
how do i test the TPS voltage?
fuel pressure regulator?
also...none of the my gague lights work? so i dont know if the check engine light is on? could a fuse cause the whole gauge cluster not to light up?
i sure as hell hope not if so theres going to be one pissed of old man at my house
Aliate X
602
Rockland NY
May 14, 2007
#29
  • May 14, 2007
  • #29
ryan218 said:
shut it....my lifters arnt broke push your pile off a cliff...at least mine moves under its own power
lol Ill bet I can push mine faster than you can drive yours considering you arnt legally allowed to drive!
ryan218
Dec 28, 2005
columbus ohio
May 14, 2007
#30
  • May 14, 2007
  • #30
link?
RsStanG1987
569
9
79
Dupont PA
May 14, 2007
#31
  • May 14, 2007
  • #31
Oh btw 87-88 no check engine light..
ryan218
Dec 28, 2005
columbus ohio
May 14, 2007
#32
  • May 14, 2007
  • #32
whats up with that?
ryan218
Dec 28, 2005
columbus ohio
May 14, 2007
#33
  • May 14, 2007
  • #33
and mine still runs
RsStanG1987
569
9
79
Dupont PA
May 14, 2007
#34
  • May 14, 2007
  • #34
ryan218 said:
whats up with that?
It will come on but it dosent function correctly..
ryan218
Dec 28, 2005
columbus ohio
May 14, 2007
#35
  • May 14, 2007
  • #35
why?
G
getusummm
156
#36
  • May 14, 2007
  • #36
basic tuneup? plugs, cap, rotor, wires? O2 sensors? You really need to set the timing.If it sounds like a lumpy cam, you are pretty car off.The car is old, check all the vac hoses also. Even though it doesnt have a check engine light, it can still have codes to let you know whats going on. The procedure is in the tech section.
ryan218
Dec 28, 2005
columbus ohio
May 14, 2007
#37
  • May 14, 2007
  • #37
yeah...only thing i havent done is coil, dis, and O2 sensors
RsStanG1987
569
9
79
Dupont PA
May 14, 2007
#38
  • May 14, 2007
  • #38
Question is why did you mess with the timing without a light? Also is your spout connector in?
RsStanG1987
569
9
79
Dupont PA
May 14, 2007
#39
  • May 14, 2007
  • #39
I know a decent amount about speed density cars which you have.. Check all the vac hoses for leaks and get a timing light. Also is your firing order right?
93GTosu
183
#40
  • May 14, 2007
  • #40
ryan. seriously, if you need a timing light i have mine right here. i can bring it over, we can check your timing and be done with that. i dont think you shouldve been messing with it without a light.
i also have a cheapo actron scanner that'll pull your codes for you.
LMK i'm over near the osu campus.
  • 3
  • 4
  • 5
F
Fox 1990 Mustang GT 5.0 A9L – Engine suddenly shuts off but immediately restarts when key turned
  • FishermansFriend
  • Aug 9, 2026
General karthief
Hard to start when engine is cold
  • 86_Capri
  • Mar 11, 2026
2K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 21, 2026
CAMTWO1070
Engine Random hanging idle
  • 706 Saleen
  • Feb 11, 2026
Fox 5.0 Mustang Tech Feb 19, 2026
86HO5.0
C
Engine Idle cuts out
  • claypoolxx
  • Mar 7, 2026
Fox 5.0 Mustang Tech Jul 24, 2026
alutwon
E
2007 GT Stalls when lights or a/c turned on
  • ejscarfo
  • Jun 22, 2026
  • 2005 - 2009 Specific Tech
2005 - 2009 Specific Tech Sep 26, 2026
manicmechanic007
