Air Bag Light: DTC 12: Lost Battery Feed
1105
I AM the random post master...bow down
May 3, 2003
3,841
Daytona Bch, FL
DTC 12: LOST BATTERY FEED
Normal Operation
The air bag diagnostic monitor measures the voltage at Pin 14 of the air bag diagnostic monitor connector. Voltage at Pin 14 should be equal to battery voltage. If the voltage at Pin 14 drops to less than 8 volts, the air bag diagnostic monitor will flash out on the air bag indicator a DTC 12. If the voltage at Pin 14 drops to less than 5 volts, the DTC 12 will also be stored in memory. Should the loss of battery voltage at Pin 14 be intermittent or repaired, the air bag diagnostic monitor will flash out a DTC 52 (or higher priority code if one exists) on the next ignition switch cycle.
I'm lost :confused: Can anyone give me a more simpler version of what has been stated there? I got that information off of this website http://www.veryuseful.com/mustang/tech/airBag/airBag95.html#CODE12
I got the code yesterday after I had unhooked only the negative battery wire and did some welding on the drivers side panel that I'm putting in. Anyone have any idea of what I should do? Also, where is the litte plug that you can reset the light with? I saw the picture onthe website but cant find anything that looks like it. Are they refering to Pin 14 on the CCRM? If so, how do you tell which one is Pin 14? Also, which fuse is for the airbag so I can check that too? I think I might have a short in one of my ground wires and it blew the fuse. I hope thats all it is... I dont want to be searching around everywhere for the problem.
