  • SN95 4.6L Mustang Tech
air conditioner problem
  • Thread starter Thread starter mustangcam
  • Start date Start date Aug 12, 2006
M
mustangcam
70
Pensacola, Florida
Aug 12, 2006
  • Aug 12, 2006
so today a really loud noise started coming from under the passenger side dash where the fan for the a/c is. this noise only comes on when i turn on the a/c. it is just a whirring noise if anyone knows what im talkin about. does this means that i need to replace the fan or that something got sucked into it? thanks in advance.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Los Angeles, California
Aug 12, 2006
  • Aug 12, 2006
your A/C clutch is more than likely taking a chit and needs to be replaced
Mike97gt
it doe snot
10,633
the people's republic of massachusetts
Aug 12, 2006
  • Aug 12, 2006
Does it make this noise when you use heat or just Vent.. because if it's under the dash thats where the blower motor is. Because it does not make any sense if it's only on A/C since the heater/vent/a/c functions all share the same blower and temp blend door.
The a/c compressor clutch the above post is referring to is under the hood. it's mounted on the front of the A/C compressor and what it does is allow the compressor clutch to freewheel when you are not suing the A/C I doubt this is your problem if you hear a whirring noise under the dash..
I think the most likely cause of this problem is something has gotten into the blower motor.. either a object of some sort or some sort of vermin.
03ghoststang
Well-Known Member
Jul 16, 2005
1,930
Aug 12, 2006
  • Aug 12, 2006
i agree with svt also on the blower motor i forgot to post it on my previous post
Mike97gt
it doe snot
10,633
Aug 13, 2006
  • Aug 13, 2006
I am sure you missed that he said the nosie is under the dash, I have done that before on here ... as long as he is right on where the noise is I don't see what else could be the problem..
M
mustangcam
70
Pensacola, Florida
Aug 13, 2006
  • Aug 13, 2006
ok my dad said that something probably got into the fan somehow. i'm guessing the fan he ws referring to is the blower u are referring to. so can i fix this or do i need to take it in?
Mike97gt
it doe snot
10,633
Aug 13, 2006
  • Aug 13, 2006
yeah me and your dad are talking about the same thing. It's not a hard job at all. under the passenger side of the dash youi will see the blower fan motor in the case, just remove the 4 8 mm bolts and take the connector off.
nwapache
313
Seattle,WA
Aug 13, 2006
  • Aug 13, 2006
I had a dead mouse stuck in my blower motor once...the smell was worse than the sound
urban96
bubb rubb says:"woo woooooo"
3,464
Syracuse, NY
Aug 13, 2006
  • Aug 13, 2006
yea really easy job, just make sure you dont mess up the foam seal thats on there or youll get air blowing out
M
mustangcam
70
Pensacola, Florida
Aug 13, 2006
#10
  • Aug 13, 2006
  • #10
haha. it was a napkin that got sucked up in there. it was makin a lot of noise for a napkin. i took it all apart and thats all that was there and so i put it back together and turned the air on and no noise. problem fixed, and now i understand how my a/c works. thanks for the help.
M
Bad starter?
  • mason5.0
  • Oct 6, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 6, 2026
General karthief
D
Loud noise(s) from Engine Bay
  • DuluthFoxbody
  • Oct 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Nov 5, 2026
AeroCoupe
92 5.0 almost starts
  • Steverino
  • Sep 23, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 25, 2026
General karthief
08 Mustang gt high pitched noise from rear
  • sainto
  • Jun 30, 2025
2005 - 2014 S-197 Mustang -General/Talk- Jun 30, 2025
sainto
G
Resolved Smoking Wiring Issue After GT40 Head Swap
  • Grapes
  • Aug 15, 2026
Fox 5.0 Mustang Tech Aug 22, 2026
Grapes
G
