I have all of the underhood of my car stripped down. I am going to be welding and smoothing out the engine compartment. My last step is the air core, not the condenser, the core in the dash. I am doing an a/c delete. I have read how to take the core out, loosen the dash, and remove the heater box. But heres my question, to save me alot of work, can I just cut the 2 pipes that go to the air core, and weld a plate over the hole. I just figure this will save me the nightmare of ripping the dash and etc apart. Also there is almost no weight savings with the air core. In another words, pull the piece of rubber out of the firewall, stick a dremel or something in a few inches, cut the pipes, and weld a plate across. I will be leaving the heater core, because I do want heat. thanks for the advice.
.. BUt it turned off ..
