air/fuel gauge
You can tap into the HEGO signal wires at the ECU. To see both banks, you can use a toggle switch. We are talking about a NB gauge, I assume.
Good luck.
$uperstang said:
I was thinking of installing one of these too. Is it necessary?
Nope... it's not necessary and it's almost pointless unless you just like the pretty lights.:D The stock narrow band sensor doesn't have enough of a range to provide any usefull information when just wired to a gauge.
Here's a little writeup I did some time ago that might help explain the "why" a little better.
http://forums.stangnet.com/showthread.php?t=544703&highlight=air+fuel+ratio
I suppose it would tell you if an O2 or its wiring had totally taken a dump though. I seem to recall that Jamie found a dead O2 this way. We dont tend to put a meter on the O2 wiring that often otherwise.
