My friends and I finish putting the air/fuel ratio meter on my car, and it shows that is running lean. I don'nt know why but black smoke is comming out from the mufflers like is running rich. How do i know if we are connecting it right, does it need to be connected on both O2 sensors, because i only connected on one.
The idle on it is also rough, We trying to figure out what it is. I put the 42lbs injectors with the 90MM MAF meter conversion.
My fuel pressure is at 38psi. The timming is at 10 degrees. Any help is appreciated.
