i just put in 42's and a calibrated blow through maf in my 95 with a turbo. no tune on the factory computer my air fuel is reading 11.1-11.3. is this normal or should it be in the area of 14.5-14.7?
this not quite accurate ...i would say without a tune, yes.
someone correct if i'm wrong, but the calibrated MAF only gets you close but you need a tune to finish it. your injectors are still staying open as long as the 19#s were, but since you now have larger holes, there is more fuel going in each pulse. so you will be rich. again, getting a tune should clear it up. the only other thing that i can think of would be to back off the fuel pressure, but then you'll be hurting yourself in WOT and higher RPMs.
Also to note the "cheat" mafs tend to be off or have issues the larger you go from stock.
Honestly, with the options out there either get a LMAF (if your looking at around 400-450wrhp) or an SCT maf. The tune will be miles ahead and with less headache for you and the tuner.
At idle a boosted car should not "see" any boost and normal A/F ratio's apply...IE targeting the 14.9 range. 11's is super lean.
