About 6 weeks ago I changed my radiator, water pump and stat. The radiator and pump are summit brand. In the first week or two I had some problems with intermitant overhearing, and having a hard time getting the air pockets to bleed out. I solved these problems buy using a mr.gasket 180 stat. with a 1/8 hole drilled in the stat. at the top. For a few weeks now everything has been great. Engine temps stay between 180-195, I have plenty of heat and I am not using any coolant. Also no leaks any where. I still have 1 issue that I cant seem to resolve or get a solid answer to. when I am pounding on the car and into boost my overflow tank goes from just high enough to keep the low coolant light off to sometimes comming out of the spout on the overflow tank. Also after an extended drive of 15-20 min. whenm I shut the car off I can easily hear gurgeling comming from my overflow tank and then through the heater core. I check for leaks every where and Im 100% positive there are no leaks from the radiator to the heater core. I was told by some one that they thought that I might have a failing head gasket near a water jacket and when I get into boost Im forcing air into the water system. I dont want to tear down my top end unless im sure because this is my daily driver and it cold outside yet. Anybody have any thoughts on what is going on.
