Cobra4075 Founding Member Feb 18, 2002 286 1 17 Tinley Park, IL Jan 24, 2007 #1 Jan 24, 2007 #1 Since I no longer have to go for emission tests, I'm looking to ditch the air pump on my 91. Will the stock computer throw a code?
jrichker StangNet's favorite TOOL In Remembrance. Thank you for your contributions Mar 10, 2000 27,512 2,811 234 Dublin GA Jan 24, 2007 #2 Jan 24, 2007 #2 The computer won't miss the air pump, but it will miss the TAD & TAB solenoids if you disconnect them. A 70 ohm, 2 watt resistor soldered and heat shrinked across each of the solenoid connectors in place of the solenoids should eliminate the codes.
