air shocks
  • Thread starter Thread starter niteninja87
  • Start date Start date Jul 10, 2009
N
niteninja87
11
  • Jul 10, 2009
am i able to put air shocks on my car? its a 87 gt, its my 1st mustang and its all new to me. but i seen that there are 4 shocks in the rear. why is there 4? i had a 87 iroc and it just had 2. but back to my ? do i need to buy 4 air shocks since there is that many back there or just 2?
Mustang5L5
Mod Dude
Feb 18, 2001
43,371
18,119
224
Massachusetts
Jul 10, 2009
  • Jul 10, 2009
Air bags replace the springs, not the shocks.
The two verticle shocks are the suspension shocks. The two horizontal ones are axle movement dampeners which help control wheel hop during hard launches.
Any reason why you want to add air bags?
N
niteninja87
11
  • Jul 11, 2009
well the car is lowered and its a really ruff ride, and i was told that if i put air shocks on that it would soften up the ride a little.
for the axle movement dampeners when do those need to be replaced?
thanks steve
Vinnietbird
584
  • Jul 11, 2009
You should be able to install air shocks just fine without removing the quad shocks,and run the lines to an easy to get to place,but away from any moving parts.I think they only cost about $70.00 a pair (at least around here).I have a set on the Bird.Nice ride.I am assuming you mean air shocks,and not air bags...right?
rbonella
409
@ home
Jul 11, 2009
  • Jul 11, 2009
If I were you, simply replace your stiff springs with something a little more plush. A lot of guys will put in a road race spring at all 4 corners which is cool, but if you daily drive your stang it can become tiresome pretty quick. Don't put in air shocks, airshocks are for vehicles that take on heavy loads in the rear so you add more air to compensate for the added weight OR 79' camaros or el caminos with jacked up rear ends lol. Air ride shocks are not too pricey, but all the supporting hardware is...regulators, air tanks, lines, fittings, install. It can easily approach $1000+ quickly. Get some softer springs and call it a day
2000xp8
SN Certified Technician
Aug 8, 2003
8,075
1,658
194
NJ
Jul 11, 2009
  • Jul 11, 2009
The only good air bag equipment for a mustang is the air ride technologies.
But, it's expensive as hell. Air Suspension Specialists | Air Ride Technologies ? RideTech.com
Check out the mustang section, they have some pretty cool stuff, i think even including struts that eliminate the springs.
If your ride quality is an issue, you probably need some new shocks, isolators all the way around and maybe some springs.
I put the koni red adjustables on my car, and on the softest setting there it definitely rides better. I'm sure other brands work similarly.
N
niteninja87
11
  • Jul 11, 2009
yea i ment air shocks, so what are the best shocks that i should go with?
J
Engine Stalling
  • josh40tay
  • Oct 20, 2026
JD1964
J
i need help
  • JK.
  • Oct 24, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2026
JD1964
  • brandyn200
  • Jun 20, 2026
AeroCoupe
Engine My Gates K060845 (85 1/4”) belt doesn’t fit
  • Mcmahst
  • Jun 26, 2025
Fox 5.0 Mustang Tech Jun 27, 2025
Mcmahst
W
Front ATS brakes with Taurus rear brakes. Full parts needed?
  • Wagonized
  • Sep 24, 2026
Fox 5.0 Mustang Tech Sep 25, 2026
General karthief
