air to my 331 ?'s
  • Thread starter Thread starter riceslayer302
  • Start date Start date Jul 12, 2008
riceslayer302
Banned
Oct 3, 2006
CT
Jul 12, 2008
  • Jul 12, 2008
im trying to decide what size fuel injectors, mass air, and throttle body to get for my 331 stroker project. this will be a N/A 331 at 10:1. I am using a 280/286 .598 lift comp cam, AFR185 58cc heads, and an edelbrock rpm 2. I am hoping to make some good power with this combo, but how much, i dont really know, AFR's website has cars with setups like mine making 475 to the crank.
My questions are, what do you guys think i should use for fuel injectors on this setup? what brand is best? i was thinking of going with MSD or FRPP. I was thinking somewhere between 24 and 30# injectors, but what do you guys think?
Mass air, i know i need to get mass air that is calibrated to my injectors, but what size? they have them all the way up to 90mm, which i dont understand because 90mm mass air going into a 75mm throttle body doesnt make much sense.
Throttle body, i am not sure but i think the throttle body opening on the RPM II is 70mm? Should i get a 70mm throttle body or get a 75 and open up the intake a little bit?
thanks for the advice in advance! :SNSign:
Markus
238
germany
Jul 12, 2008
  • Jul 12, 2008
Hi,
i drive a 331 stroker too. On the top i have a GT40 with ported lower. I use a 65mm tb and a matched 75mm pro-m mass air with a cold air intake. The injectors are 24#.
Heads are AFR185 (10.7:1) and a ed curtis custom cam (.5728/.5632 lift, 224/228 @.05). Long tube headers, off road exhaust. A Tweecer RT is on board too.
My car is pulling 350PS (DIN, rear wheel).
I think with your intake and a 70 or 75mm tb the 475 hp are not unreachable. Is a 90mm mass air not too big for a na 331?
The mass air should be a little bigger than the tb.
I don´t use the full capacity of my 24 pounders. I drive with stock fuel pressure.
Markus
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 12, 2008
  • Jul 12, 2008
75tb open the inlet, 80-90mm mass air, 30-42lb injectors.
My 30lb injectors are 100% maxed out @ 96% duty cycle before I hit my shift point in my 347.
riceslayer302
Banned
Oct 3, 2006
CT
Jul 12, 2008
  • Jul 12, 2008
holy **** you think i need 42s?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jul 12, 2008
  • Jul 12, 2008
Killercanary has some very accurate datalogging material and he hit 36X RWHP in his N/A 331 with just 24 lb injectors. He was running 82% duty cycle by the way.
A 70 mm TB will flow plenty for your combination, I promise.
As for the MAF, read this from a guy that has a 352 cubic inch engine and runs low 11's @ 122 MPH in the quarter mile:
It made 411 rwhp with the pro m 77. I then put the abaco 97 dbx MAF with the bell on it and it made the exact same power, 411.
You do not NEED a 80-90 mm MAF for flow reasons, but they make some very accurate ones in that range. Just thought I would make that clear.
Venom351R
4,548
41
98
MAINE
Jul 13, 2008
  • Jul 13, 2008
Nothing new to add from what's already been said b/c I agree but I do have a set of FMS #24 injectors that need a new home.
1991vert
1,103
Ludlow, MA
Jul 13, 2008
  • Jul 13, 2008
mike, a 90mm MAF for sam's 331? are you joking?
sam who is tuning this car? it's best to call and ask for opinions. i'd go one step up from 24#'ers though
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 13, 2008
  • Jul 13, 2008
Size doesn't matter, calibration does.
Like I was saying I don't know how wild your combo is, but im 100% maxed out with my 30lb injectors @ a very accurate 96% duty cycle before I hit my shift point in my 347.
riceslayer302
Banned
Oct 3, 2006
CT
Jul 13, 2008
  • Jul 13, 2008
i listed a rough idea of my combo up top. right now i think i am going to go with 32#'s with a 75mm TB, and open up the RPM II a little. how does this sound? as for the mass air i thought it was supposed to be a little bigger than the TB? so 80-90mm would be ideal correct?
1991vert
1,103
Ludlow, MA
Jul 13, 2008
#10
  • Jul 13, 2008
  • #10
when i talked to mike in CT, i told him i was planning on using a 90mm MAF for my blown 363. he simply asked, "why?"
Grn92LX
Fidanza Man!
6,819
64
129
New York
Jul 13, 2008
#11
  • Jul 13, 2008
  • #11
Yup 30's, 75tb and 80-90 mass air should work fine
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Jul 13, 2008
#12
  • Jul 13, 2008
  • #12
No need to open up anything, but that is up to you.
Many people think that size in MM is how to judge a MAF or TB, but they all flow differently, even if they are both 80 mm and 80 mm.
The bigger is better idea is not needed, if you understand how much air an engine actually pumps in and out. The parts quoted above flow in the 1000 + CFM range, when your engine may pump out 600 CFM.
Engine 1988 Ford Mustang throwing 2 OBD-1 codes (32 and 63) rough cold start and initial idle
  • mikeah
  • Nov 16, 2026
Fox 5.0 Mustang Tech Nov 17, 2026
mikeah
Engine 91 mustang 302 Low acceleration car backfires pops and acts like it doesn’t want to take fuel
  • 1991Fox5.0
  • Oct 4, 2025
Fox 5.0 Mustang Tech Oct 6, 2025
1991Fox5.0
Fox Mass Air Flow 42lb injectors
  • 89wreck
  • Aug 18, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 5, 2025
Scrapla347
A
Blow through intercooled questions
  • AngryH58
  • Aug 31, 2026
1996 - 2004 SN95 Mustang -General/Talk- Sep 1, 2026
AngryH58
A
  • Mindseye007
  • Aug 16, 2026
Mindseye007
