AIRBAG CODE 31
  • Thread starter Thread starter 93_SVT_FREAK
  • Start date Start date Dec 2, 2008
93_SVT_FREAK
515
Missouri
Dec 2, 2008
  • Dec 2, 2008
I have searched, But can't find what I'm looking for........And I have been here too
http://www.veryuseful.com/mustang/tech/airBag/airBag92.html
MY 92 GT is flashing code 31 ( All system air bags open)
The air bag has gone off and I'm going to buy another airbag.
The driver's side sensor is scratched but not pushed in
Do I need to get another sensor? Will the new bag blow up too when I hook the battery back up?
I just want to install the new bag and get the light to stop blinking.
Thanks,
dcurtis
688
Dec 2, 2008
  • Dec 2, 2008
Isn't a code 31 for the EGR?
stang&2Birds
2,091
New England. :-) CT/MA
Dec 2, 2008
  • Dec 2, 2008
93_SVT_FREAK:
First: I hope you, your car, and everyone else are okay!
Hi. I just scanned an uploaded the following:
http://www.veryuseful.com/mustang/tech/airBag/images/AirBag92Code31-Page1of2.pdf
http://www.veryuseful.com/mustang/tech/airBag/images/AirBag92Code31-Page2of2.pdf
A few things:
1) No worry at all about a new air bag going off! NONE! If a sensor was jammed "on", the diag controller would see that, report that, and blow the internal safety fuse after 3 ignition turn ons.
The first/second gen air bag controllers are a dual stage setup. There's a safing sensor that gets activated at ~5mph (head-on crash into brick wall). Then, the main sensors get activated at ~15mph (head-on crash into brick wall). So, if any sensor is "stuck on", that's easy to detect, and the diag control blows the internal safing fuse.
2) My guess is that you see the error because of the activated air bag. That's easy to check! Just remove/disconnect the air bag and see if the code changes to a code 34.
**NOTE TO OTHERS:
Since his air bag has deployed, he does not have to disconnect the battery and wait ~1min to perform the above test. But, for non-deployed air bags, you MUST ALWAYS disconnect the battery FIRST, then wait, then remove/disconnect the air bag.
93_SVT_FREAK when you connect your new air bag, then you MUST disconnect the battery, and wait ~1min. No big deal.
BTW: I don't think that the pages I uploaded will be of a lot of help to you since the cause of the error code is likely the deployed air bag . But, they are good reference so that you have a idea of what the error codes means, why you're doing the test I suggested, and what it all means.
However, it is possible that when you do the test, you still get an error 31. In that case, my guess is that the clock spring went because of the current that was used to deploy the air bag. That does happen in some cases. Ford does recommend that the clock spring be replaced after an air bag deployment. But, I don't know if you can even get a new clockspring any more. And, very few small body shops replace the clockspring.
Let me know the result of your testing.
Good Luck!
stang&2Birds
2,091
Dec 2, 2008
  • Dec 2, 2008
The air bag in a Fox flashes it's codes by the air bag light. In a Fox, the air bag system is 100% separate from everything else - it's a 100% stand-alone system.
So, the EEC codes and the air bag codes are separate, and the codes are obtained by different methods.
dcurtis
688
Dec 3, 2008
  • Dec 3, 2008
Thats cool, I never knew that, good to know for the future though.
93_SVT_FREAK
515
Missouri
Dec 4, 2008
  • Dec 4, 2008
Well my fix was simple........All I did was plug the new airbag in, Hook the battery back up and no airbag codes......I thought forsure I'd have to get a new clock spring.
:SNSign:
stang&2Birds
2,091
Dec 4, 2008
  • Dec 4, 2008
:SNSign:
Cool!
Glad everything is working again.
Electrical Code 29 again
  • Creomod
  • Jul 31, 2026
Fox 5.0 Mustang Tech Aug 3, 2026
Creomod
W
I need a 1997 Mustang PATS A expert!
  • Wolfdogg
  • Oct 2, 2026
1996 - 2004 SN95 Mustang -General/Talk- Oct 5, 2026
T
Drivetrain TREMEC TKX 1–2 Grinding Issue at ~4,000 Miles + Poor Warranty/Customer Service Experience
  • Ttopfoxguy
  • Oct 10, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
JMG9350
J
Fuel ‘88 GT Runs Rich Cold — Fixes Itself When I Unplug Sensors (ECT, MAF, O2, etc.)
  • Sufarry
  • Nov 6, 2025
Fox 5.0 Mustang Tech Nov 9, 2025
Mustang5L5
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
