Alcohol 331
  • Thread starter Thread starter bditty50
  • Start date Start date Jun 14, 2007
bditty50
170
Tampa, Florida
Jun 14, 2007
  • Jun 14, 2007
I want to build a motor that runs on alcohol and gas what do I have to do on my build for it to handle both fuels?
smallstang393
75
  • Jun 14, 2007
That motor could be run either way but you would have to change fuel setup because alch. takes like twice as as much fuel to run it. alch. runs cooler but needs twice as much to use it but there not a way (that I know of) you can run both setups without changing a good bit of your setup
bditty50
170
Tampa, Florida
Jun 14, 2007
  • Jun 14, 2007
well what about the flex fuel cars that run on ethanol and gas?
smallstang393
75
  • Jun 14, 2007
Thats not alcohol thats diff. your talking about two totally diff things
Wallzy
128
Orlando, FL
Jun 14, 2007
  • Jun 14, 2007
If you are planning on running a carb setup, you will not be able to do it; the jetting is way bigger for alcohol.
If you are planning on running fuel injection, you are going to re-run everything and make sure that it is all alcohol compatible...alcohol is pretty evil stuff and likes to destroy, corode and gum up everything. Also, you are going to need fat enough injectors to handle the alcohol content without upping your fuel pressures to an insane amount. You will also need to have a programable fuel injection system that can switch between an alcohol program and a gas program. The final thing that you may have to adjust is the ignition timing alcohol likes to be further advanced - like racing fuel; the alcohol will run ok at 10-15deg.
My final question to you is: Are you planning on driving this around on the street or track only car?
-what ever your plans are be aware that you can not see alcohol burning, you feel it burning and by then it's too late. Wear a nomex suite.
Paint and Body Door Latch Issue
  • KRUISR
  • Oct 9, 2026
Fox 5.0 Mustang Tech Oct 15, 2026
General karthief
Electrical Spark Plugs
  • jimzzilla
  • Feb 24, 2026
  • 2 3
Fox 5.0 Mustang Tech Feb 28, 2026
jimzzilla
H
Forced Induction On3 Turbo Kit- Parts list NEEDED - 302 Stock Motor
  • Hirothecool1
  • Feb 27, 2026
2K
Fox 5.0 Mustang Tech Mar 7, 2026
slow84lx
N
Engine 86 GT no start/stall
  • nweber
  • Jul 28, 2026
Fox 5.0 Mustang Tech Jul 29, 2026
AeroCoupe
Fuel SN95.0 fuel system
  • RedFury5.0
  • Apr 22, 2025
Fox 5.0 Mustang Tech Apr 22, 2025
AeroCoupe
