Or even an aluminum Mark 8 4.6 DOHC Motor! Not to dis the Nav's motor, that sucker would be awesomely sweet too! That's something worth considering. You could find an ol' Lincoln Mk 8 for pretty cheap these days, pull the motor and rebuild the aluminum block with forged internals, port the heads, install some good cams and get cobra intake manifold installed. Should be a real sweet setup with about a 9lb psi KB blower on it too!ProCharger GT said:put in the navigator engine![]()
9646gt said:what is the cost of the explorer engine..I want pi heads but no use with the mileage on the bottom end of my motor..I would be much more intrested in doing a motor swap to tell you the truth at this many miles
putting a brand new top end on a worn out bottom end is something a ricer does with a honda..I think i will jsut wait till I can swap the hole thing..besides ..I wont have compression issues this way so I can still be boosting without tearing into the motor to change the pistonsgit-it-83 said:at 170K and counting, you are thinking in the right mindset
9646gt said:putting a brand new top end on a worn out bottom end is something a ricer does with a honda..I think i will jsut wait till I can swap the hole thing..besides ..I wont have compression issues this way so I can still be boosting without tearing into the motor to change the pistons![]()
