All Kinds Of Problems!!!!
Firstable, last nite my friends and I finished installing the SC on my car. After the installation all kinds of problems appear.
1. AFR meter was reading lean, but the smoke that was comming from the mufflers indicated that it was running rich. I check the last post i place last night, and it seems that the AFR meter was connected wrong. I would fix that right now and see if that was the problem.
2. the idle on the car is rough, we are thinking is the MAF meter. The MAF meter is a 90mm, calibrated for 42lb injectors. It is possible that my computer is not accepting the readings from the MAF meter because of the year of the car. 90mm are use in newer style vehicles an my car is a 91GT, can that be the problem. Should a tunning would get that problem out of the way.
3. it took the car for a spin and when i was comming to a complete stop the car would die on me. When i was trying to turn the car on again, it would take a while, like if the injectors were getting to much gas.
4. I also upgrade my alternator to the 94/95 style. The battery light is on now, but the battery guage is showing that is charging. what can it be.
Any help is appreciated. Thanks
