- Mar 20, 2017
- 133
- 12
- 28
93 mustang gt 302 5 speed. Currently I am running only the130 alternator/ water pump and crank. I bought an alternator bracket from amazon and removed the stock bracket with the tensioner. Now I’m also going to be converting to electronic fans. My issue is now, since my belt routing will be different I had to get a cw water pump. Got one from an 89 crown Vic, I hear the stock mustang smooth water pump pully will work I would need to open up the bolt holes a little to mount it to the water pump. Does this all sound like I’m going in the right direction? If not what pully should I use? Any pictures from anyone’s setup like I have? I wanted to remove as much as possible near the alternator because in fall I start installing an on 3 turbo kit.
