aluminum driveshaft
  • Thread starter Thread starter hsean
  • Start date Start date Dec 1, 2008
First Prev 2 of 2
hsean
656
69
69
dearborn,michigan
Dec 2, 2008
#21
  • Dec 2, 2008
  • #21
i am going to buy one in an hour you guys sold me on it.now if i could get an even trade for a 3.73 for my 4.10
MAC'n89Blckstng
1,012
NJ
Dec 2, 2008
#22
  • Dec 2, 2008
  • #22
I put one on my car and it was my favorite (non go fast) mod I put on my car. I got her up to 140-150 ish and the car was as smooth as glass. I will never run a stock driveshaft ever again. Oh and you shave a whole lot more than 3-4 pounds. I would say the aluminum shaft is about half the weight of the stock steel shaft.
hsean
656
69
69
dearborn,michigan
Dec 2, 2008
#23
  • Dec 2, 2008
  • #23
i picked it up for a hundred bucks and boy it is light the guy has this motor on an engine stang that is all done up with heads and all kind of machine work.he says that the motor will make my car a 12 second car if i put the right cam .it gives me something to think about i have a stock 88 roller motor with an upper and lower cobra intake.the lower is mildly ported.if i were to go with this motor than i would have to keep my cage because i have a t-top car.
Dino Dino Bambino
1,672
89
79
Cyprus
Dec 3, 2008
#24
  • Dec 3, 2008
  • #24
You're close. I've weighed both and the stock steel driveshaft is 20lb while the aluminium unit is 11lb.
MAC'n89Blckstng
1,012
NJ
Dec 3, 2008
#25
  • Dec 3, 2008
  • #25
lol, pretty good for a guess. Thats alot of rotational mass.
Metalcop
148
New Hampshire
Dec 3, 2008
#26
  • Dec 3, 2008
  • #26
Don't forget the the junkyard option, the aluminum driveshaft out of certain year AWD Aerostars is the same part the Ford Racing gouges you $300+/- for.
hsean
656
69
69
dearborn,michigan
Dec 3, 2008
#27
  • Dec 3, 2008
  • #27
the guy i bought this from told me it might need some new u joints and that they are fairly cheap .where can i buy this from?
cenok is family
1,409
69
79
Norman, Ok
Dec 4, 2008
#28
  • Dec 4, 2008
  • #28
any auto parts store. is it a ford racing one or one from a windstar?
hsean
656
69
69
dearborn,michigan
Dec 4, 2008
#29
  • Dec 4, 2008
  • #29
how can you tell if it is a ford racing one or an aero star one?there isn't any markings that i can see.
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Dec 5, 2008
#30
  • Dec 5, 2008
  • #30
hell no there not useless! i have one on my D.D 4banger! Well i also have alum steeda lower rear control arms 8.8 out of an 89 5.0 with 3.55 gears slotted drilled front rotors lowered. I got mine from a 96 areostar van AWD i had to get the rear ujoint and convert it to a mustang diff. So the driveline was $20 u pull it and the u joint (heavy duty) $8.00 Just make sure if you get one from a van it's a 96 or 97 cause they have welded ends and the tranny yoke is the same just not the diff end. But it's gotta be a AWD van! it takes a 12 MM 12point boxed end wrench to take them off and you also might want a nice 2-3 ft pipe for leverage. peace
john
SMOKEDYA
20+ Year Stangneter
Jul 13, 2003
3,637
Tucson AZ
Dec 5, 2008
#31
  • Dec 5, 2008
  • #31
oh yeah the only way to tell if it's a FRPP one or one out of the vans is the $200 price diffrence OR if they havent changed the rear u joint. But then also like i stated MAKE SURE it's out of a 96 or 97 cause they are welded NOT pressed in ends on them. NONE of the FRPP ones have pressed in ends either, so if you buy one make sure the ends are welded. OK so buy the drive shaft remove the rear u joint. remove your stock rear u joint take both of them to the parts store and tell them you need to make this go to this. problem solved. peace
john
hsean
656
69
69
dearborn,michigan
Dec 5, 2008
#32
  • Dec 5, 2008
  • #32
john
that is probably what i will do is take the u joints in to the parts store thanks
hotcobra03
poteet,tx
Dec 5, 2008
#33
  • Dec 5, 2008
  • #33
Ford uses 3 basic sizes of ujoint.1310,1330,1350.best i can tell u for difference 1310 is less than 3 and a half inch with a 1 inch whole(bearing cap).1330 is wider than 3.5 and has 1in cap. 1350 is the same as 1330 but has a 1and a quarter cap.spicer ujoint 4 1310 is 5-153x. 1330 use 5-1203x to combined the two use 5-134x. If rear pinion yoke is ubolt style 5-1204x has the larger bearing cap 1 and an eight .note alum shaft does require different type ujoints.
cenok is family
1,409
69
79
Norman, Ok
Dec 5, 2008
#34
  • Dec 5, 2008
  • #34
they aren't the same as the ford racing driveshafts. the ford racing driveshafts have a larger diameter than the aerostar ones. someone on here had a pic of the two side by side...the ford racing one is larger than a stocker and the aerostar is close to the same diameter as a stock steel one.
hotcobra03
poteet,tx
Dec 5, 2008
#35
  • Dec 5, 2008
  • #35
If your not running 10s .dont worry about strenght.camaro has ran a 2 and 3quarter round shaft and .i made shafts 4 etown and atco racers.even in a modified they have been 2in and now up to 3in . You can pull shaft anything its only a size and ford doesnt make it anyway spicer does
hsean
656
69
69
dearborn,michigan
Dec 6, 2008
#36
  • Dec 6, 2008
  • #36
mine is definately larger in diameter than my stocker thats cool to know
Foxfan88
My Grandpa has great wood.
Sep 13, 2004
2,487
Miami, Ok
Dec 6, 2008
#37
  • Dec 6, 2008
  • #37
i run the FMS alum shaft. i was skeptical about buying one new, BUT i bought it new for around 240$ and it cured all my driveline vibrations i had due to a gear swap.
First Prev 2 of 2
Clicking sound from driveshaft/rear differential
  • matthewt
  • Aug 27, 2026
  • 2015 - 2023 (S550) Mustang -General/Talk
2015 - 2023 (S550) Mustang -General/Talk Aug 28, 2026
matthewt
351w aluminum oil pump?
  • Kid wita 5oh
  • Oct 28, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Oct 28, 2025
Mustang5L5
H
Aluminum timing chain guides ?
  • healy1963
  • May 5, 2026
2005 - 2014 S-197 Mustang -General/Talk- May 5, 2026
healy1963
H
Cleaning up Aluminum
  • limp
  • Mar 11, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 13, 2026
KRUISR
Progress Thread 91GTstroked 90 7 up convertible build
  • 91GTstroked
  • Apr 18, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 22, 2026
91GTstroked
