I've had 100 people look at my car on ebay but no bids. Do I have it overpriced?
http://cgi.ebay.com/ebaymotors/Cars-Trucks___1994-Mustang-GT-5-7L-420hp-AirRide-Susp-17K-in-mods_W0QQitemZ330282108773QQddnZCarsQ20Q26Q20TrucksQQddiZ2282QQcmdZViewItem?hash=item330282108773&_trksid=p4506.c0.m245&_trkparms=72%3A727%7C65%3A12%7C39%3A1%7C240%3A1308
Black 1994 Mustang GT 5 Speed, 347 Stroker engine – 420hp! This 5.7 liter engine has only 4K miles on it and was built by Tachyon Automotive with only the best parts (see below). It was dyno tuned to 420hp by Dynotune Performance. The car chassis has 140K miles on it but most of the suspension has been replaced. The car sports an AirRide Coolride suspension so you can control your ride height and firmness with just a push of a button! The interior has some nice touches with aluminum accents and like-nice leather/suede cobra seats. A/C and heater works. See below for extensive list of modifications:
Engine:
5.7L CHP 347 Stroker Engine
Engine Tuned with Diablosport/Revolution Chip
K&N Filer
Pro-M 77mm MAF
Edelbrock 70mm TB
Edelbrock Performer RPM II Intake Manifold
Air Flow Research (AFR) 185 heads
Aluminum Ford Racing Valve Covers
1.7 ratio Crane Cams Roller Rockers
Anderson Ford Motorsports B-21 CAM
Probe Forged Pistons
Chromolly push rods
ARP Bolts in Bottom End
CHP aluminum main girdle
Fluidyne Aluminum Radiator
Oil Cooler
MSD Distributor/Wires
Kirban Fuel Pressure Regulator
Fuel Pressure gauge on fuel rail
Ceramic coated Long Tube Headers
Hi Flow Cat H-pipe
Edelbrock SDT Mufflers
Stainless Steel Tailpipes
Steeda Power Pulleys
Smog Pump Delete Kit
Drivetrain:
King Cobra Clutch
FMS Aluminum Drive Shaft
Steeda Tri-Axe Shifter
Adjustable Clutch cable; firewall adjuster
Ford Racing 3.55:1 gears
Suspension:
Air Ride CoolRide Suspension
Tokico Illumina 5-way adjustable Shocks and Struts
Maximum Motorsports Caster Camber Plates
2003 Cobra Front Control Arms/Bushings
Polyurethane Front Sway Bar Bushings
Baer Bump Steer Tie Rod Ends
Maximum Motorsports Steering Rack Bushings
Steeda Heavy Duty Upper Control Arms
Lower Control Arms with Polyurethane/Spherical Bearings
Cobra R Replica Rims [17”x9”f; 17”x10.5”r]
Sumitomo Tires [255/40/17f; 315/35/17r]
Battery Relocated to Trunk
Brakes:
2000 Cobra R Brembo Front Brake Kit
2003 Cobra Rear Brake Kit
Stainless Steel Braided brake lines front and rear
2003 Cobra Master Cylinder
Interior:
2003 Cobra Seats (gray leather/suede) – like new
Aluminum door sill plates – Late Model Restoration
Aluminum door handles – Late Model Restoration
[F500] Leather Steering Wheel
Leather Shift knob
Autometer Water temp gauge
Autometer Air-Fuel Ration gauge
Steeda Aluminum Pedal Covers
CD Player
Aftermarket Keyless Entry
Exterior:
ABC Cobra RR Hood/Hoodpins
Projector Headlights
1996 Style Tail light conversion
Thanks for your input.
Engine:
K&N Filer
Pro-M 77mm MAF
Edelbrock 70mm TB
Chromolly push rods
Oil Cooler
Hi Flow Cat H-pipe
Drivetrain:
King Cobra Clutch
Suspension:
Brakes:
Interior:
Leather Shift knob
CD Player
Exterior:
I have used that site for each of my listings that i have and they sold pretty fast. That is where alot of people go to get cars that are modded or built. Should try it. Just don't put possible trade on it, unless you want to trade for something, cause you usually get alot of low ballers on there that wanna yank your chain for crap that needs alot of work for your car that needs nothing lol. But yeah put it on there for firm and put no low ballers and see what you get. Just let me know what you think. BTW your car looks really good, like the air suspension pic.
