am i doomed?
carbed87
215
just a quick question...
alright, so after i put my cast-iron gt-40's on and felt an overall power LOSS, as well as stil not getting them to run right, i have thought about just putting my stock ones back on. i was just wondering if i would have to change out any of the gaskets i put in under 50miles ago. i mean, they havent even been in there twoo weeks, so do you think they'd be alright being reused? just thought i'd ask.
you lost power because somthing during the swap was not done, or done incorrectly. Swaping heads will only help at this point if you manage to stumble across somthing you may have forgotten during the initial swap. Root cause could be vac leak, ground loose missing (O2 ground wire was off for me...huge difference when corrected), could be incorrectly set up valvetrain..COULD be lost of things...you need to make a list of possibles and walk through cheking them all off. I once found a vac leak on my little girl after honestly well over 5 time checking..right in the passenger fenderwell..5th time was the charm, end result my car idled and ran great for the first time in months.
I agree w/ DMAN - you should not have lost power by just upgrading heads.
Don't be hard on yourself and I'm sure it was an honest mistake, but something is wrong.
Let me ask this: Did you torque your rockers down using the proper method? If you're not sure, you could search on stangnet and find the best method...I'd try to find a post where Michael Yount has written the method out - I know he did so for me a couple years ago. Even if you used the proper method, they can still possibly loosen; mine were loose one time and I couldn't even get it out of the driveway - I don't think I torqued them at all though lol - rookie mistake.
Are you sure you have your distributer installed correctly? What is your timing set at? What is your fuel pressure? What is your spark plug gap? Did you get all of your connectors hooked back up? What's your TPS voltage?
As DMAN pointed out, make sure you have all of your grounds hooked back up. Never hurts to have too much ground; I got a 4ga starter wire from autozone and attached it to the timing cover where the stock battery ground is and ran it to the firewall. I can't remember the length - but I believe I got one around 36" or so - just measure and see how long you want yours if you want to do that.
Re check the torque on your lower intake as those bolts often loosen up up after heating and cooling a few times - gotta pull the upper to check; however, I doubt that's the cause of your problem.
Possibly the most important: Do you have any check engine codes? If you haven't pulled them, here's a method outlined by the infamous Jrichker showing how to do it w/ just a paperclip or jumper wire: http://forums.stangnet.com/showthread.php?t=566924 - 4th post down
Post back up w/ questions/results.
Good Luck :nice:
check it out like the above!! most of the time it IS just a overlooked "Little" thing!! As far as re using the gaskets...?? take a chance and have to do it AGAIN!! I have, however, reused the GOOD felpro intake and head gaskets with " high Tac " spray on them and RTV silicon... but... like a I said .. Take that chance????
Just me..........................
Thumper
carbed87 said:
any other input other than how stupid i am?
They're not saying you're stupid, they're agreeing with Thumper, if that's what you meant by your last post.
What all did you do when you did the heads? Did you do the cam at the same time? Or did you already have it in there? I'd definitely pull the codes and see what's going on. You could also try a compression test to see if maybe your rockers are too tight causing the valves to not close fully.
no, i had the e-303 in there before, and i shouldn't have tightened one of the rockers too tight, because i tourqued them all down to 20lbs with a "click-click" tourque wrench
