AN fitting ?'s
Roland69
Sergeant Tangnet
Sep 17, 2005
2,867
Port Elgin, Ontario
never delt with them much before. I want to use the rails that came with the GT40 intake. they have some AN fittings and I don't know what size they are. I think I can get some adapters to fit my stock fuel lines to some AN fittings then stainless braided line then fittings to the rails. (if that makes sence. What I need to know is what size are theese and what do I need to make it work with my car with stock fuel lines
and I am guessing the bigger one would be for the feed and the smaller one for return
you will need to switch your rails around, if you are using the stock fuel lines put the rail with the 10an fitting at the pass front, your loop line or connector should be in the back of the intake and the 6an should be at drivers front to hook up to factory line return. you can get the adapter fittings to go from the stock lines to an style line at UPR, RUSSELL, or CENTRAL COAST
