Another “which mods next”?
Curse
791
El Paso, TX
I need help choosing my next modifications. With my currant combo, I ran a 13.4 (without the N2O) at 4500FT of elevation, by comparison 06 Mustang GTs run low 15s to high 14s here. I want to break into the 12s all motor before I spray.
This will be tricky to analyze, since I run at a fake track that has no 60FT. times, or MPH. My 13.4 run was made with a stock FPR with the fuel pressure being at 50 psi @ WOT:eek: and the ports on my Typhoon are a lot smaller than the Trick Flow ports. I have fixed my fuel pressure problem. The only thing I don’t really want to change are the rear-end gears and my cam.
So my current upgrade lists looks like this, feel to make your suggestions/changes.
1. Have Tmoss port my lower, I think the mismatched ports are hurting me bad.
2. Control arms, drag struts/shocks (using stock stuff now)
3. Advance cam 4*, I hear the stage 1 cam runs awesome like this.
4. This is a distant number 4. I want to try long tube headers, but not sure the performance will be worth the money headers are $230 + $130 x-pipe and $300 cat-back=$600 for a few HP:shrug:
Let’s hear your inputs guys, I want a 12 sec all motor car.
what is your air fuel ratio. At that altitude it is probably very rich. if you are not tuned for the alt you could pick up a lot of hp with a good tune. Also get the suspension stuff for your next mod. it will help you the most.
I haven't taken my car to get tuned yet, but you are right with my old combo, my A/F was very rich. I was launching at 4500rpm running 26x8.5-15 ET drags and my car was hooking hard, but I guess you can never have enough traction. I am leaning towards Steeda Adj. Uppers and not sure which lower yet, it will either be Lakewood Traction Action bars, or the HPM Mega bite jr.s
Keep them coming guys:nice:
Flavadave4 said:
why dont you want to change your gears?
I think it would put you where you want to be and it is a relativly cheap upgrade
Well I already have 3.73s and I do some highway driving. With the 3.73s, I am turing 2500+ RPM @ 75mph. If I go more gear, I don't think she will be to good on the highway.
