i have heard alot about this motor or at least that people seem to recomend doing it and i was woundering if it would be a good reliable engine. or if the power they are claiming is not realistic? http://www.carcraft.com/techarticles/116_0307_ford_302_v8_engine_buildup/ i have a 89 5.0 that is not running correctly and i have my 66 wich is my daily driver now and i was woundering if i could swap my 5.0 into my car i know it is a easy swap specially since i wont be going to EFI but my questions are is the above combination worth it and waht would i have to change in my 66 coupe to put it in? are many of the parts on the motors interchangable? i have a 4 speed top loader and was curious if that would stand up to the power the above link is claiming? i did a search for the information on the 5.0 swap but most of what i got was EFI related i just want to know if my pulliies and accesories will switch over i have power steering and will be having and A/C unit shortly.. any advice would be great thanks again guys.
The flywheel will be cheaper if you switch to a diaphram clutch & pressure plate then you can use the factory 5.0 T5 flywheel. The rocker selection will depend on what heads and stud arrangement they have. If you're able to, choose a set with 7/16" studs, these are the strongest. Rocker selection is narrowed somewhat but 1.7 rockers for them are available. These are what I have on my 331. The rockers are Comp Cams "engine builders" line, these aren't advertised and are only available thru professional engine builders but are a good bit less in price than the ones Comp advertises.
