another AODE shuddering
johnmc302
17
Texas
My trans has the shudders at around 40 mph light acceleration. I am going to try and do oil/filter change this weekend.
I live in Chandler Texas and was wondering if anyone knows of a decent trans shop in the area? I just moved here from Florida.
I had one done several years ago and am wondering if an Art Carr or other specialty trans would be a better bet than a local rebuild?
I could go on with quesions all night but I will sit back and see what responses I get.
Thanks,
John
John,
You have torque converter clutch shudder. Here's some info I've posted before in this problem.
Short story: You will eventually have to replace the torque converter in your transmission.
Long story: There are a couple of things you can do to get some more life out of your current torque converter and postpone the inevitable replacement.
Torque converter clutch shudder in AOD-Es in 94 through 98 Mustangs is a know problem. Ford has issued about three or four different Technical Service Bulletins regarding the issue, but no recalls!
At any rate, the symptom is a shudder coming from the transmission (feels kind of like you are driving over a series of those little speed bump strips) when you are driving at “light to moderate throttle” (the words in the TSBs).
The problem as stated by Ford is two-fold. The first cause is a breakdown of the friction properties of the older Mercon IV and earlier transmission fluid due to heat build up. The second cause is undersized friction plates in the torque converter clutch in the torque converters on all AOD-Es from 94 to 98. The combination of these two problems results in a grabbing-slipping, grabbing-slipping, etc. of the torque converter clutch during shifts at light to moderate throttle. As soon as you “get on it” the shudder goes away!
I had this problem on my stock 95GT. I followed all the advice in Ford’s TSBs. Replaced the tranny fluid with the new synthetic Mercon V and installed an auxiliary tranny fluid cooler. For the first 2,000 miles after that, I had no more shudder, so I thought it was fixed. But then it came back. (The Ford TSBs say that if the symptom returns within 10,000 miles you have to replace the torque converter because the clutch is just too far gone.)
At any rate, I wasn’t about to go through that expense yet, and I heard about a product by LubeGard called, “Dr. Tranny’s Instant Shudder Fixx”, that was supposed to work some magic on the tranny and stop the shudder. It’s a small 5” long red tube of what looks like regular tranny fluid, but its actually a friction modifier that acts on the torque converter clutch friction surfaces. About $10.00 to $15.00 bucks a tube depending on where you get it.
I put one tube of that stuff in my transmission, cycled the gear shift lever through the gears, backed out of the driveway, and drove off. No shudder!!! Gone!
So, for $10.00 bucks or so, I’d say give it a shot. It’s only 2 oz. of fluid so you won’t have to drain any out before adding it. Just add it to what’s in there now.
If you can’t find the stuff at a transmission shop, here’s their web site. You can buy it direct from them on line.
www.lubegard.com/automotive/index.html
From their home page, go to Transmission Products, then to the link for Dr. Tranny’s Instant Shudder Fixx.
After about another 2,000 to 3,000 miles the symptoms returned. After that, even another tube of this stuff would not stop it. The problem is that the torque converter clutch friction plates are just too burned/glazed to recover.
You’ll eventually have to replace your torque converter.
John
Great Info :hail2:
Data explaining the prob
Data from experts explaining the fix
Data from one (you) giving findings from real world experience
I'm sure it will he helpful to auto peeps :nice:
Grady
thanks for the replies
Hey everyone thanks for the great info,
I was wondering one thing, if I replace the torque converter what are the chances of the transmission smoking the torque converter?
The fluid in the trans looks fine and does not smell burnt. I have the money for the torque converter now but was waiting because I figured the trans would need a re-build also.
I may try the Tranny "gue" MLC stang wrote about depending on what other feedback i get.
At this point I am thinking just replace the torque converter and be done with it, but as stated above I do not want to pull the trans twice.
Thanks and keep it comin,
John
John
John,
Two things in response to your comments above.
1. The tranny fluid doesn't need to smell burnt in order to have this problem. It's an issue with the friction coefficient of the tranny fluid being reduced over time with heat and age.
2. Don't do what I did and only replace the torque converter without rebuilding the rest of the tranny at the same time! (I ended up doing it in two stages over a years time and thus having to pay to have the tranny removed from the car twice! DUH!) The labor for the tranny removal is half the expense of the job, so get the whole thing rebuilt at one shot.
Hey Guys,
Just did a trans filter and fluid change, and added "Gue" Hopefully I can get a year of so. I know wishfull thinking, if it does go I will probably buy a but a Lentch(sp) package deal and jsut install myself.
I will keep you all posted
John
