- Mar 30, 2005
- 10
- 0
- 0
I'm about to upgrade my stock bottom end, street driven 87 GT with AFR 165cc heads, GT-40 intake, Holley adjustable fuel pressure regulator, 70mm throttle body, 75mm Pro-M MAF, 24# injectors, and a set of 1.7 roller rockers that i've had for a while. I was going to stick with the stock cam which is why i got the 1.7s off a friend for cheap, but now I've decided to go with another shaft. The 1.7s have kinda limited my cam choice with stock pistons and the 1.90/1.60 valves. I don't wanna spring the extra cash for 1.6s unless absolutely necessary. Here's what I'm thinking now:
E303
TFS Stage 1
AFM N-21
Right now I like the E-cam as it'll have .529 lift and 220/220 at .050 with 1.7s. I think this'll run good down low and have plenty up top also. Let me know what you think of these shafts, or suggest a better one if you know of one.
E303
TFS Stage 1
AFM N-21
... i would go with the TFS Stage 1
