Just a simple question, does frpp makes the 3.90 gears for an 02 stang, I've gone on there site and couldn't find it, I was thinking about those gears as I cant make up my mind on 3.73 or 4.10. Where is a good cheap place to buy gears also ?
_StangGT__ said:Thats pretty cheap, is motive as good as frpp as far as reliability ?? If not I'll just go with 4.10.
_StangGT__ said:Just a simple question, does frpp makes the 3.90 gears for an 02 stang, I've gone on there site and couldn't find it, I was thinking about those gears as I cant make up my mind on 3.73 or 4.10. Where is a good cheap place to buy gears also ?
BooWFO said:If your not going to do the install yourselve, check with who is. Some people will only do FRPP gears. If your gonna stay NA then go 4.10's unless you engage in HIGH speed runs then you do kinda run outta gear. In which case 3.73's.
_StangGT__ said:Thanks guys for all the great info, I've done quite a bit of reading on gears and I'm still not sure of the ratio hehe anyways 3.90 seems like a good one of me, too bad frpp doesn't make them.
Does putting motive gears or any gears will void the warranty ?
dont take my word on that though. make sure you talk to the shop that will be doing the install before you order. find out if they require an install kit, or what brands they will work withWord - got both 3.73s and 4.10s...now I only wish we had 4.10s in both. I wouldn't settle for less than 4.10s and not for less than FRPP.flashstang04 said:4.10s are completely streetable......Just gotta re-learn to drive.
twogts4us said:I know some who have put 3.90s in and had the whine...and were told, "Oh that's normal for these gears"
