Another Need Combo Advice Thread
  • Thread starter Thread starter poneypower89
  • Start date Start date Oct 3, 2005
poneypower89
Now everyone in the world will know I wanna bang t
Dec 6, 2004
Indianapolis, Indiana
Oct 3, 2005
  • Oct 3, 2005
Alright, sorry for another one of these threads but I want a personalized combo advice session
Alright, the current mods are:
1. 3:73 Gears
2. BBk H-Pipe
3. Flowmaster Exhaust
4. Vortech SC-Trim Super Charger (@ 6 Psi)
This winter the car will be parked so there will be a lot of downtime to work on it. The plan is to get a set of Thumper Heads and a Typoon Intake. I've decided on these for two reasons. Price and effectiveness. I've seen people with this combo and the boost turned up put the Power into block splitting territory. Anyways, I do not know what I should get as far as...
1. TB
2. MAF
3. Injectors
4. Cam
I need to know what TB, MAF, and Injector combo will work best with the mentioned combo and the boost turned up to around 10psi.
CAM: It has to be blower friendly and off the shelve. I really dont want to mess around with a custom grind. I've thought about just keeping the stock cam and running some 1.7rr's. I've heard people say it still gives a slight cam sound and a few HP and that the stock cam is a fairly good blower cam as it is.. so what should I do?
So, if anyone has any opinions please let the advice fly and if you could give me a little reason why its best to go with your advice.
Grn92LX
Fidanza Man!
6,819
64
129
New York
Oct 3, 2005
  • Oct 3, 2005
70mm tb, 42lb injectors, prefessional mass air 80mm maf, AFM blower cam. You could do the stock cam/1.7 thing. Judging by your parts selection, you're not going for big power so maybe that'll be good for you.
poneypower89
Dec 6, 2004
Oct 3, 2005
  • Oct 3, 2005
Big Power is subjective
I really just want to go deep into the 12's with a good set of slicks and still keep the car as a DD. I believe the boost should make up for lack of expensive heads.
Edit: Are 42lb injectors really neccessary? I've heard people having problems getting 42lb injectors to feed the idle and wot correctly... usually the idle is the messed up instance with 42lb lnjectors... of course, this is just coming from hear-say I could have just been listening to a bad source. Will a slightly smaller injector be able to feed the engine without a FMU. (Im not against 42lb injectors, just curious as to if they are actually needed)
K
kevsstang
143
pa
Oct 3, 2005
  • Oct 3, 2005
You might be able to pick up a explorer intake cheaper than the Typhoon. You could also send the lower to TMOSS.
Like Mike said go with the 70mm TB, 80 mm Mass Air. As for the 42lbs injectors you can probably get away with 36's but do it right the first time and get the 42's. This way you will have room to grow in the future. Then you can ditch the FMU.
poneypower89
Dec 6, 2004
Oct 3, 2005
  • Oct 3, 2005
Alright, I guess I got an agreed census for the tb, maf,and injectors... but what to do about the cam?
Anybody else want to throw in ideas?
Progress Thread Progress Thread- From6to8's 95 GT/Saleen Supercharged 331 install
  • from6to8
  • Mar 22, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 28, 2026
from6to8
  • 68_Disgustang
  • Feb 22, 2026
1965 - 1973 Classic Mustangs -General/Talk- Oct 19, 2026
mattcrp1
M
  • Gulftown980x
  • Jul 29, 2026
  • SN95 4.6L Mustang Tech
squeak93
Progress Thread Progress Thread- From6to8's 1994 Cobra Supercharger install
  • from6to8
  • Sep 25, 2025
  • 20 21 22
11K
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- May 6, 2026
from6to8
Which one of these 3 intakes make the most sense for my 331 combo
  • from6to8
  • Jul 25, 2024
  • 1994 - 1995 Specific Tech
2K
1994 - 1995 Specific Tech Jul 26, 2024
AeroCoupe
