Another power estimate thread: 351W
SadbutTrue
2,390
Granada Hills, California
351W
.030 over
Comp 274XE cam
Weiand Stealth
Ported stock heads
1 5/8 headers into 2.5" exhaust
Flowmasters
MSD 6
Accel super stock coil
I asked for this before I think, but I did a search and couldn't find it. D'oh. Oh, and if anyone knows how much power would be gained with Trick Flow Twisted Wedge or Performer RPM heads added, feel free to enlighten me.
Thanks
what compression? 10- 11.1 and what carb.
i myself would go for the afr's 165's at the least if you plan on buying heads.thats what i should have done.
head bolt on about 20 rwhp with edelbrocks
with the setup you listed i get this from Engine Analyzer:
Ported Stock Heads:
387 HP @ 5500 RPM and 405 lb-ft @ 4500 RPM
AFR 165:
395 HP @ 5500 RPM and 406 lb-ft @ 4500 RPM
looks like a pretty good combo to me... your exhaust is probably holding you back a bit, but other than that looks good. the AFR/Ported difference would likely be a lot larger as it seems the head specs in Engine Analyzer are fairly aggressive (stock GT40 heads net 349 HP @ 5000, 384 lb-ft @ 4500).
Ported Stock Heads:
AFR 165:
thanks bullitt, and whoa, i was expecting more in the 330 range at the crank, with that combo looks like I'd make more like 300 at the wheels. Wow, and that is pretty crazy cheap too...
i have 351w victor heads 2.05/1.60/ flow # are [email protected] 291/ex.@700lift 198/ solid roller cam 246/256-626/[email protected] srp flattops 11.1 comp. super victor intake hp.750 carb with 200hp nos tko trans alum drive shaft s/s/bars 8pt. cage/lt.we.ft k-member 8.8 with 3.73s/ hoosier tires 27x11.50 15 car runs [email protected]t dyno ,last motor i dynoed the guy blew it up!all in a 83GT that i bought new .
