  • 1994 - 1995 Specific Tech
Another problem
  • Thread starter Thread starter mytight95
  • Start date Start date Oct 31, 2004
mytight95
2,605
Dothan,Al
Oct 31, 2004
  • Oct 31, 2004
first off let me start with this
Well i let the car up to full temp today.........for the first time since it has been put back together..........and i have a very bad water leak........
upon further inspection etc........i found it is coming from where the coolant tubes thread down into the lower intake...........IT is cracked (intake that is) ........now here is my question i have over 150$ in port work on that lower....... plus powdercoating........can it be fixed such as drilled out larger and retapped and threaded to fit the coolant tube threads.......
so far that is the only problem i am seeing........but i expect more
someone please give me my options........other than a new intake. i want one but can't really afford it yet
jason
4Jenna
4,326
AZ
Oct 31, 2004
  • Oct 31, 2004
Maybe it can be welded up...take it to a machine shop and see what they say.
95BLKGT5.0
608
Auburn Washington
Oct 31, 2004
  • Oct 31, 2004
Yes you could drill it out and retap it.
The problem is do you know where the crack stops.
We have a spectrograph (spelled wrong) that we use to check for cracks.
What you do is put this powder on the part than look for cracks with a type of black light.
Almost like magnafluxing.
A place that does alum. work like a machine shop might beable to help you.
RIO5.0
6,892
N.H.
Oct 31, 2004
  • Oct 31, 2004
Damn....That blows... You mentioned awhile back about the coating being in all the threads??? What'd you use for a thread sealer...you sealed it right???
Do you see a crack running down the threads???
If your in a jam send it up...I can weld/repair it...you should be able to get that local fairly easy..That does suck though..Murphys Law.
mytight95
2,605
Dothan,Al
Oct 31, 2004
  • Oct 31, 2004
i amy take that up with you andy........kinda poor right now....again...lol
i used thread tape..........not much either.......the bung that it threads down into is cracked pretty good too........i will take a pic tommorrow.....
this sh** sucks a**
thanks for the suggestions........i am gonna call a few places tommorrow....
jason
mytight95
2,605
Dothan,Al
Nov 1, 2004
  • Nov 1, 2004
there are some sequential pictures to show where the crack is at.....you can see it easily in the last pic........but i took the others so you could tell where it was at on the intake.....
jason
what do you guys think
RIO5.0
6,892
N.H.
Nov 1, 2004
  • Nov 1, 2004
Well..its a good one....
rout it out, weld it, re-tap...least the pc hasn't broke off....looks like a tit repair...
Just looking at that...it looks like you really buried that fitting...mine sticks up like 3/8" from the intake....did we happen to "reef" that mother in there???
94TURBO5 O
2,509
VA
Nov 1, 2004
  • Nov 1, 2004
JB WELD dude will fix that up real nice. It's cheap and if you take your time and do it evenly it will dry nice. Just make sure you prep clean the area real good and get all the coolant and oil off of it.
mytight95
2,605
Dothan,Al
Nov 1, 2004
  • Nov 1, 2004
think jb will hold it..........what if i had to pull it off again........don't know if i could get to all the intake bolts to remove it or not..........
what do you guys think.........
andy, "reef", man i don't know what that means.....i would assume muscle it in.....whatever the problem is i am sure i created it......lol....kinda....
anywho, i don't really want to pull it back off....but i guess i may have to. Although that JB weld idea sounds pretty good i don't know it it would hold...
jason
94TURBO5 O
2,509
VA
Nov 1, 2004
#10
  • Nov 1, 2004
  • #10
I'm pretty sure it'll hold if you clean it good and let it dry properly. Just try not to get it on the nut in case you have to get it off again but if you get it on there you can crack off the weld.
mytight95
2,605
Dothan,Al
Nov 1, 2004
#11
  • Nov 1, 2004
  • #11
i may try that.........i dunno........i guess it would be worth a try....
jason
94TURBO5 O
2,509
VA
Nov 2, 2004
#12
  • Nov 2, 2004
  • #12
Let me know how it goes, it should work out for you fine.
mytight95
2,605
Dothan,Al
Nov 2, 2004
#13
  • Nov 2, 2004
  • #13
well JR.........i am in the process of trying the jb weld.......I took my dremel and one of the cutting burrs and kinda created a "trough" or a bevil so to speak for the epoxy to sit in......I hope this will work....i completely cleaned the paint off the thing about 1/2 inch on either side and kinda created a place for the epoxy to settle.......also tried to mush it in the cracks.....etc etc. etc.
i hope this works..
RIO5.0
6,892
N.H.
Nov 3, 2004
#14
  • Nov 3, 2004
  • #14
You'd be surprised what that stuff will hold...great idea SC!!!
my son dumped his Honda 50 once and cracked the side cover popping out a pc..JB'd it and it lasted and never leaked...that was inside the primary cover..
To install my new VCs i had to open a 1" hole to clear the alternator as it was hitting....i used Aluminum tape on the I.D. to form it...then JB'd inside and out, sanded to form...no leaks...stuff does work the balls...
I would take that heater tube out and try to get a die to chase those threads though if they have any sign if powdercoating on em ???
good luck...
mytight95
2,605
Dothan,Al
Nov 3, 2004
#15
  • Nov 3, 2004
  • #15
where could i find a chase that large.......i bought a tap set when some of the others wouldn't do right......i didn't see anything even close to that thread size etc......
set the other day andy before the crack was found........it revs fast nicely and sounds like it'll make some power......it is louder i guess as a result of the shaved heads.......i am excited.
94TURBO5 O
2,509
VA
Nov 3, 2004
#16
  • Nov 3, 2004
  • #16
I asked on the other thread...But how's it working for you??
mytight95
2,605
Dothan,Al
Nov 3, 2004
#17
  • Nov 3, 2004
  • #17
i think it is still leaking.............very very slightly..........howefer i did take it around the block sorta kinda creeping...............lol
:biggrin:
it's quick..........
jason
jason
mytight95
2,605
Dothan,Al
Nov 12, 2004
#18
  • Nov 12, 2004
  • #18
thanks on the JB,...........Jr
it is working splendidly......it was my ect sensor leaking not the crack.....
nice idea, and mucho thanks
jason
Fuel rail help
  • stang9150
  • Mar 3, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Mar 5, 2026
stang9150
J
  • Locked
SOLD 93 cobra intake manifold
  • Jimmer009
  • Jan 19, 2025
  • Engine and Power Adder
Engine and Power Adder Jan 22, 2025
Jimmer009
J
Engine Motor swap from a 2003 Explorer
  • 1996mustang new
  • Oct 9, 2025
  • SN95 4.6L Mustang Tech
SN95 4.6L Mustang Tech Oct 16, 2025
squeak93
KNOCK WITH CLUTCH OUT
  • Scwhitten
  • Apr 13, 2025
1996 - 2004 SN95 Mustang -General/Talk- Apr 22, 2025
89ripper
SURGING IDLE / NO IDLE CHECKLIST FOR 1999–2004 MUSTANG GT (4.6L 2V) - Work In Progress
  • Noobz347
  • Aug 30, 2025
1996 - 2004 SN95 Mustang -General/Talk- Aug 30, 2025
