Another question....
  • Thread starter Thread starter Shakin66
  • Start date Start date Nov 23, 2008
Shakin66
628
Waycross, Ga / Lake James, NC
Nov 23, 2008
  • Nov 23, 2008
I am in the process of installing this digital 7 with boost control and have a question as to where I should hook up the Map sensor so that it reads the intake pressure correctly. I have a fitting on the blower discharge tube or there is a couple of fittings on the carb. (Berry Grant). The fittings on the carb are either ported or constant vaccm???I also could use the larger fitting on the back of the intake I guess.....Obviously I am confussed.
brianj5600
1,964
Middle TN
Nov 23, 2008
  • Nov 23, 2008
I would not use the blower discharge. With the map not seeing vacuum you will not be able to have more advance at cruise. I used the small fitting at the passenger side front of the baseplate. The large on at the back is fine too. It will take an adapter though. I use small black zipties to help secure them.
Shakin66
628
Nov 23, 2008
  • Nov 23, 2008
You have a great point and I'm glad you responded as I was hooking it up to the blower tube. My Demon has two ports side by side, one is Timed vac. and the other is onstant Vac. Any I dea which yours is conected to? I have the boost gauge, the Digital 7 and the Fuel pressure regulator all needing a boost hook up so I just want to do this one time. I had the Gauge connected to the dicharge tube but it never really moved much so I am going to move it also.
brianj5600
1,964
Middle TN
Nov 23, 2008
  • Nov 23, 2008
The regulator needs to be before the carb.
The MAP needs to see vacuum and boost, the ported will not work.
If your gauge is straight boost put it before the carb. If it is vac/bst, put it to the same place as the MAP.
Fox '87 GT can't get to stay running
  • spilly
  • Mar 29, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Jun 20, 2026
spilly
For Sale Hogans Racing Intake manifold for SBF
  • Bullitt347
  • Jun 7, 2025
  • Engine and Power Adder
Engine and Power Adder Oct 8, 2026
Qtrhrse23
H
Engine 1987 5.0 HO vacuum hose locations
  • harryhaber
  • Jun 20, 2025
Fox 5.0 Mustang Tech Jun 21, 2025
limp
Block questions
  • s_vargas54
  • Jan 25, 2026
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Feb 8, 2026
Trogdor
CFI to carb conversion question
  • StockerStang
  • Mar 23, 2025
1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk- Sep 11, 2025
AeroCoupe
