Went to a car show on sat evening and had the top down for the day. By night fall it got really cold, below 10 deg celcius. So when I decided to put the top back up I couldnt latch it. It took quite a bit of muscle to latch one side then the other. Some one did mention about not using the top if its cold. Anyone here expericence anything of the sort before. Im a virgin at verts.
One more, driver side rear side window doesnt exactly operate like the pass. I wount come all the way up unless you pull it. Is this a common problem? Is it usually a regualtor assembly that need replacing or just the motor not powerfull enough to raise. It just makes alot of clicking noises up or down. But if you give it a small push on the way down it drops fine. Up is another story
thanks
thanks
