Another wheel question.
2002MineralGray
48
Ok sorry if this sounds dumb. Im about to order a set of 17" black bullitts for my car. Was gonna get some 17X8s but then I saw the 17X9s on Americanmuscle.com. But I only have the stock size 245 tires on my car now and can't afford new tires yet and they recomend 275s to be put on a 17X9" wheel. But then I saw that Americanmuscle says its dangerous to put a smaller tire size than what is recomended. Yet in the next sentence they say that any tire from 245-275 is good for a 17X9" wheel. So does anyone know if its THAT big of an issue to run 245s on a 17X9" rim for a bit. Sorry again if this is a dumb question but I dont really want to be driving down the road when the side wall works its way off the rim because its too small.
it is going to look very off. dangerous??? I guess if you are xracing it might be But otherwise it should work fine. You can also call your local tire shop ( discount tire etc.) some tires do run smaller than others so you need to watch for that as well.
275's look perfect on a 9" wheel. I wouldn't put 245's on a 9". They are stretched and look really stupid. Just wait until you can afford 275's. Or buy 17X8's for the front with 245's and 17X9's for the back and run a 275.
The reason they say they are dangerous is because if you run around a corner with 245's on a 9" wheel the bead might break and the tire will pop off sending you into the wall.
