I'm trying to run a list in my head of where my leak could be before I end up tearing the entire engine apart and rebuilding this bitch again. This engine has never been turned over yet and I recently replaced the timing cover. As I poured antifreeze into the radiator I could hear it spilling into the oil pan at a pretty decent rate. Where the hell can this come from?
I figure it has to come from one of the following:
- Heads
- Cylinder crack
- Block crack
- Timing cover/water pump
I don't think it could be the heads because the spill rate was too high to be a leak from either a torn gasket or improper fitting. It damn well better not be a cylinder or block crack because I just had this block boiled and blueprinted. The only thing I can think of would be the timing cover but I can't see how it would transfer from the water pump to the timing cover. There is the +/- 2 inch area at the front of the oil pan that hooks to the bottom of the timing cover but it is separated from the water pump by that plate thingy. This is the first time I've ever used a Fox style timing cover and water pump so maybe I put it together wrong...
Any ideas?
- Heads
- Cylinder crack
- Block crack
Any ideas?
