Any p to v clearances with this cam with AFR 165's?
5spd GT
"the 5.0 owns all"
9,516
Arkansas
Gross Valve Lift 1.6 Ratio is .5600 for intake and .5568 exhaust with 224/224 duration @.050 tappet lift?
Also 111 Lobe Seperation with 107 Recommended Intake Centerline...
And I am checking but wanting opinions on what you all think?
The opinions really won't help -- you have to measure because each combo, even those with identical components, is different. You might come back and let us know what the measured clearance actually was. Be sure you degree your cam before you measure. How it's installed impacts the clearances.
Thanks...yeah I know the opinions won't matter...it's more of a "piece of mind" type thing...just seeing if anyone has similar specs and was fine...
