Any problems with drops and 275 tires up front
98V6 K.I.T.T.
2,049
Everett, Washington
I'm running 275/40/17 tires up front with the stock suspension right now, along with 315/35/17's in the rear. I'm looking to get my suspension done shortly after x-mas and plan on getting H&R SS springs with MM Caster/Camber plates. The drop is 1.6" in the front. Anyone have any rubbing issues with this setup? I'm alittle worried with a drop that low and the wider tire. If there are going to be major issues I might consider going with the Steeda Sports instead which are only about 1.25", but don't like the stance as much as the H&R SS's.
with the stock h&r ss's I didnt notice any rubbing. But it wasn't low enough. The front had a 3 finger gap and the rear had a 2.5 finger gap. So I cut 1 coil off the front. Sits awesome. But at full turn and with a load on it the tires rub my fender liners
My 275/40/17's on my GT & my 265/35/18's on my Mach both rub a little on full lock turns, but its not a big deal....I plan on going with 255's in the front next time on the GT & most likely on the Mach too, because there is no need for a tire any wider up front imo....
