I had that happen to me as well when the engine was first put together. I discovered it was because the TFS valve covers don't come with built in baffles and the oil was being sucked up into my cold air intake, traveling down and draining out the fenderwell where the air filter is. I found baffled grommets and that took care of that problem .onebad50 said:I have had the same problem with my holley intake , it was so bad that i had oil running down into my air filter. What I have done is to put breather valve covers on and plug my pcv hole. It has work so far.![]()
