Any timing experts out there?
ForceFed70
That's why they call it "dope"
4,818
BC Canada
Was hoping you guys could take a look at my ignition timing table and let me know what you think.
100Kpa = No Vacum
30Kpa = Max vacum achieved while driving which is about 20" of vacum(mercury).
Engine idles at around 55Kpa = 13" of mercury
attachment.php
Not sure how useful to you this is, but vac advance normally works against a spring. Springs behave in according to f=-kx
(k=constant, x= displacement, f=force) - (http://www.pa.msu.edu/courses/1998spring/ISP209/homework/hmwk3/hwset3.html)
Consequently there would be a linear change in advance in proprtion to change in force applied by the vaccuum (i.e. negative pressure, i.e. reduction in force).
So once I get to the point - take what would be a normal vacuum advance maximum setting, and apply it in a linear fashion accross the vacuum delta. This should probably do the job until you find more solid info.
HTH
