I did mine a few weeks ago with the Trick Flow tool. None of the auto stores or rental stores around me had the OTC or equivilent tool so I ordered the TF from Summit.
It is pretty straightforward and can be done in your driveway by yourself but it is a tedious and frustrating job due to the lack of working space around the cam towers and caps.
The valves close to the firewall are indeed the worst to get too and especially the last valve on the passenger side (and the first on the driver side but at least there's space to work there) because it's almost completely boxed in by the cam towers leaving almost no room to manuever to get the keepers in. If I was doing it again, I might remove the hood for better access to the last set of valves.
Taking stuff apart was pretty easy and went quickly. A magnetic grabber popped the keepers out easily. A small pair of needle nose vise lock pliars made getting stubborn old seals out easier. Putting things back together was a real bitch though. There just isn't much room to guide the keepers into place and I thought I was beat several times. I eventually got better at it though. I magnetized a screwdriver to put them in with because the grabber was way to strong to not grab on to everything steel or let the keepers go I did get one in place somehow.
I'm not entirely sure it wouldn't have been easier to pull the cams to change the seals instead. Would've been more tearing down and bolting back together but the actual changing out the seals probably would've gone much smoother. Now that I've done it once though, I could probably do it again much quicker.
Make sure you have a breaker bar for the spring compressor and not a ratchet because the big ratchet heads will catch on the cap clusters and bind and you'll have to use an extension in some places which will put a good bit of sideways tourqe on it and make it likely to slip out. I also recommend a cheater bar so that you don't need so much force to hold the spring compressed while you're screwing around with keepers.
Good luck!
