anyone ever replaced a trans on a dodge caravan?
FWD transmissions are not fun. You have to take apart the axles, steering, and possibly some suspension just to get the thing out. If you can do all that and put it back together and make it work then go for it. Oh and I'd never consider doing a FWD trans without access to a lift. Major PITA!
We had an older fwd van i helped replace the rear main seal on. We didnt have a lift, we put the thing on jackstands, took the wheel off, tie rod end, pulled the cv joint out, disconnected all the crap (speedo cable and everything) had a dude on one side of the van, and one on the other side... used a steel pipe and a rope (yeah, we were ghetto back then) put the rope through some brackets on the tranny, took all the bolts loose, and slid the tranny straight up and out.
like i said, this was an older one, so i dont know if its the same or not.
