anyone have a custom cam and stock computer?
N8Miller
I need NOS....make it 2 of the big ones
2,661
Kingston, PA, USA
zzskyzz is debating on a cam for his winter 302 build. it is going to consist of a set of ported gt40heads, trickflow intake (eventhough i say an RPM would be better!), 24#ers, 75mm MAF, 125 shot of nitrous....etc etc
he says that the steeda #19 cam is the best for this setup. He is worried about his finicky computer. I say that a custom cam is the ONLY way to go.
any opinions?
ps: he will prolly have a tweecer to go along with it.
the 19s would probably be easier to tune with, but when he wacks the juice, going lean shouldnt be an issue. He already has a slightly larger than stock fuel pump, so 24s should be better.
I have to agree with Greg about tuning makes concern for cam choice an almost non issue.
You asked for opinions so ... here is one or two :)
Speaking from the experience of a custom cam/Tweecer/ owner
The two can be made to work together quite nicely :)
If I am understanding your Q correctly :shrug:
You seem to be saying a custom cam is about helping the pcm not freak :shrug:
If that is what you are thinking or asking ...
Here is the mind set I used to put together my combo :D
Use Cam Pro's knowledge to put together a combo that makes power
and
Use the knowledge of a Tuning Pro ... or yourself ... to tune it :nice:
If one gives consideration to the pcm when planning for a combo, they are certainly gonna leave power on the table IMHO.
Another thing is the tiny 19lb inj's ...........
They really are too small to work with much of a na combo ......
unless
you jack up the pressure pretty high.
If he has juice plans, they are all the more inadequate from my way of thinking.
Juice is not my thing but ... would 24's even be enough for a h/c/i AND juice combo.
Grady
With the Tweecer, I wouldn't worry too much about how it'll run on the stock tune. But to help you out a little with your original question, I knew I wouldn't be able to get a tune for a while so I told Ed C that and my car runs great on the stock tune. No surging/hanging idle, no smoke, and barely any low speed bucking.
reddy351 said:
He said he's going to 24 pounders.
I did see that and then went on to ask the Q
Are 24's enough if using juice
heck ... 24 ain't all that great for h/c/i combos at stock pressure
anyway ... Just more stuff to kick around and talk about :shrug:
Grady
One thing to keep in mind is that a mild grind like the Steeda #19 is no guarantee -- I've got a buddy with that cam, which he purchased specifically to avoid having to play with the EEC, and he still ended up having problems. In the end he ended up with a chip anyway.
And with that in mind...
I agree 100%. Assume you are going to have to alter the tune anyway, and then go for the stoutest cam that you can stand and that meets your goals.
And that is all you will need.
